Old Sep 15, 2014, 11:23 AM
tblount70's Avatar
United States, TN, Thompson's Station
Joined May 2004
Redesign Spars?
I'm just starting my first serious scratch build - Elf Senior Bipe. One thing I really planned from the beginning was to redesign the spars a bit. Just about every kit I've built (couple dozen) have had upper and lower main spars. Most have had some sort of shear element - either individual shear webs or some other connecting piece between the spars. At this point I'm comfortable building this design.
With the OT plans and even some not-so-old, I see one piece main spars.
Has anyone seen a thread on the ins and outs of changing the spars around? I did a little digging and didn't find anything.
Thanks in advance...
tblount70 is online now Find More Posts by tblount70
Old Sep 16, 2014, 08:48 PM
Warren B's Avatar
Mt Evelyn, Melbourne, OZ
Joined Dec 2008
I see the Elf Senior has 3/16 x 3/4 pine spars.
Putting the same amount of pine into top and bottom 3/16 x 3/8 spars with webbing (1/16 sheet balsa with grain vertical) would be a lot stronger (way more than double).
However that is not to say that the original spars are too weak, 60" is not a large wing.
The trouble with top and bottom spars with this wing is that there is no leading edge sheeting, so the top spar will show and look rather ugly (and slightly disrupt the airflow, but probably not noticeable).
If you were also going to sheet the wing LE, then top and bottom spars would be the way to go.
If you are worried I would probably just add a little to the spar width take it to 1/4" X 3/4.
More depth would have a greater strength increase, but there is not enough room in the ribs above the spar.
Warren B is offline Find More Posts by Warren B
Old Sep 16, 2014, 09:01 PM
Culper Junior
eastern pa
Joined Feb 2007
I'm in the waaaay sloooow process of building an 84" span Red Ripper which also shows original large spars.
I am switching to an upper and lower webbed spar for better strength, less weight and most importantly, I would break an unbelievable amount of ribs cutting the large notch for the original spar seeing there is only about 1/8 inch of rib above the spar.
aeronca52 is offline Find More Posts by aeronca52
Old Sep 17, 2014, 01:41 AM
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
There is absolutely no doubt that top and bottom spars with graduated webbing is structurally superior to the set up often seen on vintage designs for lower spars only. I suppose it all depends upon your views on maintaining "authenticity" - or whether you are building to fly in SAM contests which prohibit such structural changes. One weakness of the relatively massive bottom spars is that, if sized to be strong enough at the centre they will be heavier than needed at the tips; it is easier to build in tapered strength and tapered weight with the top and bottom spar/graduated webbing system.
A halfway house is to still use the main bottom spar but fit a couple of lighter spars on top as well to produce a more "balanced" structure which will resist warping and upward curving ("cow horn hedral") better.
As Warren says, without LE sheeting the top spar can be a little intrusive, however inserting riblets will help a lot.
Sundancer is offline Find More Posts by Sundancer
Old Sep 17, 2014, 02:17 AM
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Personally, I have never got on well with LE sheeting and prefer the upper spar & riblets approach with an additional 1/16" sq spar well forward just to prevent covering sag.
But I do hear that SAM has a contract out on my head.....
Colonel Blink is offline Find More Posts by Colonel Blink
Old Sep 17, 2014, 09:36 AM
Northumberland, England
Joined Jan 2007
If anyone feels that they must use a heavy single main spar to maintain an appearance of authenticity, IMO, a good compromise would be to laminate the spar.
For example the Elf Senior spar mentioned above could be laminated from 3 of 3/16" x 1/4" spruce to help stiffen it against an upward curve & counter any natural curve already present in the wood.
Better still the centre laminate could be a length of 3/16" x 1/4" using spruce for the inner 1/3 spliced to 2/3 of balsa for the outer in order to keep the tips light leaving the strength where it's most needed.
patmcc is offline Find More Posts by patmcc
Old Sep 17, 2014, 12:56 PM
Culper Junior
eastern pa
Joined Feb 2007
You are right on this. I forgot to mention I am also adding 3 small spars on top in front of the webbed spar. Maybe 1/8 or 3/16 square, full span.
Discussion Spar Slots - L.E. & Spars Un-parallel to each other waynerr The Builders Workshop 6 Apr 08, 2014 02:29 AM
Discussion Walmart is saving money by redesigning semis RumRunner_1492 Life, The Universe, and Politics 16 Mar 05, 2014 04:51 PM
Discussion Redesigning a 6pol inrunner rotor MiniDragon Electric Motor Design and Construction 3 Feb 16, 2014 09:13 AM
Discussion Redesigning the soldering iron! solderotter DIY Electronics 27 Feb 08, 2014 06:26 PM
