Old Oct 17, 2014, 12:44 AM
United States, CA, Thousand Oaks
Joined Oct 2012
5s
5S is on order, my hands are shaking already...
72dan is offline Find More Posts by 72dan
Latest blog entry: Backfire on 17 x 18 5S
Old Oct 17, 2014, 12:06 PM
Registered RC NUT!
The Snake's Avatar
United States, CA, Lomita
Joined Jun 2002
have a good flight Dan!
The Snake is online now Find More Posts by The Snake
Old Oct 17, 2014, 07:31 PM
United States, CA, Redondo Beach
Joined Oct 2013
Did you order the 1800 dinogy or the 2200 or 2700 mah
hubcapsteve is offline Find More Posts by hubcapsteve
Old Oct 17, 2014, 08:09 PM
Joined Oct 2012
battery
I ordered the Neu 1800 5S 75C
I had another Sky Lipo 4S 40C 2200 go bad on Monday. I may not have enough throttle ramp, but also the X doesn't cool that well and Sky Lipo are OK for moderate performance but I have had 3 fail now on high amp applications.
Old Oct 21, 2014, 01:30 AM
Joined Oct 2012
really tight battery fit
I got the Neu 1800 5S battery today. It is a really tight fight.
I was able to shoehorn it in but it is rubbing really hard on the front wing mounts.
If it put it in sideways it is just a bit too tall with the Velcro battery mount in place that Lenny put in there.
How are you guys fitting this battery?
Old Oct 21, 2014, 01:49 AM
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Try to put the velcro side on top of the battery and the counterpart under the wing. Then the battery will be held firmly in place as low as possible in the fuselage.
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Oct 21, 2014, 08:04 AM
Joined Oct 2013
Didn't have that problem with the dinogy 5s 1800
Old Oct 21, 2014, 10:17 AM
One Idiot is plenty...
Dbox's Avatar
Planet Earth
Joined Jun 2005
Dan,With this fit You dont need any velcro.
Battery sits tight enough between fuse and wing and not gonna move anywhere.
I dont use velcro.
Yuri
Dbox is online now Find More Posts by Dbox
Old Oct 21, 2014, 12:56 PM
Lenny970's Avatar
Greeley, Colorado, USA
Joined Feb 2000
The NEU pack fits great in my X. You may need to file away a bit of excess material around the wing bolt supports.
The Dinogy pack is a little shorter and fatter, but still fits fine too, as Steve suggested.
Lenny
Lenny970 is offline Find More Posts by Lenny970
Old Oct 21, 2014, 09:21 PM
Joined Oct 2013
If your worried about it sliding , put a piece of tape(blenderm) across top of battery then down the outside of fuse.
Old Oct 22, 2014, 12:09 AM
Joined Oct 2012
Neu 1800
Lenny
Lenny, sorry I had to dremel out your nice Velcro covered wood battery pad. Then I put a thin Velcro strip on the lowest point in the fuselage.
I agree with Yuri, probably doesn't need any Velcro, the wing is going to clamp the battery in place.
Steve the blenderm is great idea, I use that to tape down rx/servo wires, makes sense would stop the battery from sliding.
Now may be a good time to read my transmitter manual on throttle ramp. It would be nice to launch at maybe 75% throttle, not 100%.
Old Oct 22, 2014, 01:04 AM
la528it's Avatar
United States, WA, Redmond
Joined Dec 2007
Dan, the f5b guys use kapton tape, just make an x that adheres to top of lipo and runs on outside of fuse. It will not damage paint and works great. Make sure that there is no way the bolts can touch the lipo,Moshe folks screwed them into the lipo in the past and the cells caught fire, may not apply to latest x planes...
la528it is offline Find More Posts by la528it
Discussion Blade MCP X - owner's thread rchelijc Micro Helis 13062 Sep 19, 2014 10:12 AM
Discussion MCP-X thread for people that dont have a MCP-x axelen Micro Helis 186 Apr 01, 2011 01:17 AM
Data mCP X (non chat) setup and tips owners thread Cable Guy Micro Helis 9 Mar 12, 2011 11:50 AM
Build Log Build Log - ARK X-500 series build thread cfrank2005 Electric Heli Talk 30 Jun 29, 2009 12:27 PM
RBC A-4 Skyhawk build thread X.X Willmsy Electric Ducted Fan Jet Talk 6 Nov 22, 2005 10:01 PM
