Old Jan 04, 2010, 11:37 PM
Videolester's Avatar
White Rock BC, Canada's Left Coast!
Joined Dec 2009
How much free play for the inner shaft??
Suddenly my Solo is flying sluggishly, but cannot yet determine why?? I do notice that when I grab the top of the inner shaft where the flybar snaps in and also grab the lower gear that the inner shaft is connected to, there's some slop there. I can rotate the inner shaft approx 2 mm while holding the lower gear in place. Should that free play be there? Is there any other place where the inner shaft is "held" other than the 2 screws on the small metal collar below the lower gear?
Is it possible that the inner shaft is fine, but the plastic fitting on top of the inner shaft which holds the flybar is not snug on the shaft? Hard to tell if it is.
Thoughts??
Videolester is offline Find More Posts by Videolester
Help! CX2 Inner Shaft Play seuaniu Coaxial Helicopters 2 Aug 21, 2008 09:30 PM
Question How much play is too much for blade grips(HBCP2)? Odrapnew Micro Helis 3 May 10, 2007 03:21 PM
Discussion How much free play is too much? osterizer Micro Helis 9 Feb 05, 2007 09:59 PM
Discussion ??Question about play in inner shaft?? Lonestar Coaxial Helicopters 4 Jan 19, 2006 04:50 PM
How much play in your prop shaft on Hacker B20 14L Geared blfinche Power Systems 0 Apr 01, 2003 07:19 PM
