Old Jan 15, 2013, 04:29 PM
Joined Oct 2007
Storm Drone
Ok, I've got the drone assembled and it binds. However I cannot get the throttle active even though I proceed as their video shows. After putting throttle and aileron in their respective positions to activate throttle and then release -no throttle. All switches are in the up position as required. I am missing something but do not know what. I assume the receiver is binded when it becomes a solid red light and not blinking. Can anyone help? There is a bec link hanging from the gyro board but I assume it is not needed, just a auxillary. The Storm is a nice looking drone. Thanks again, Rodie
Rodie is offline Find More Posts by Rodie
Old Apr 04, 2014, 12:46 PM
budgiemurray's Avatar
United Kingdom, Scotland, Clovenfords
Joined Apr 2014
Rodie,
I had this same problem on starting the rotors.. heres what I did..
First remove the props to save you actually taking off etc.. takes 5-10 mins max but worth the hassle
Plug the Drone into the PC. switch on the transmitter then the drone as normal.
Start the Naza M lite software (I presume you have downloaded this already).. open the Tx calibration tab.
check all your sticks are moving in the direction they should be.. my throttle stick was found to be reversed.. as soon as I changed it the motors would arm and run.. safe to try if your props are off..
Hope this helps..
budgiemurray is online now Find More Posts by budgiemurray
Discussion Helipal Storm Drone S2000442 Multirotor Talk 57 Apr 26, 2014 04:09 PM
Discussion Test Flight Drone Storm FF kingmicka Switzerland 2 Sep 20, 2012 11:42 AM
For Sale NIB Storm 70 & Storm 70 HW hole digger Aircraft - Electric - Jets (FS/W) 2 Jun 17, 2012 12:15 AM
For Sale NIB Hoffman Storm 70 & Storm HW hole digger Aircraft - Electric - Jets (FS/W) 6 Jun 09, 2012 11:18 AM
Sold New Storm 70 & Storm 70 HW hole digger Aircraft - Electric - Jets (FS/W) 3 Apr 06, 2012 05:10 PM
