This thread is privately moderated by loudt2, who may elect to delete unwanted replies.
Old Mar 06, 2012, 06:22 PM
Joined Mar 2012
Trader Rating: 7
Wanted
5.8 GHz 200mw Tx from FPVHobby
I'm trying to get my hands on a 5.8 GHz 200mw Tx from FPVHobby. Apparently, the ones from FPVHobby have voltage regulators built-in. (I already burned up a non-regulated one). Unfortunately, FPVHobby is sold out! I'm willing to pay really good money if you've got a Tx to spare. I live in San Francisco, USA. Thanks!
loudt2 is offline Find More Posts by loudt2
Old Apr 12, 2012, 01:44 PM
Unregistered User
cmanley_nl's Avatar
The Netherlands
Joined Jul 2010
Trader Rating: 0
I advise not to buy from FPVHobby. I've been stung for no reason after a couple of orders and so have others. Just search google for FPVHobby and rcgroups and read the bad rap for yourself. Adnan, the owner, has serious issues dealing with customers.
As an alternative you can buy a tiny and cheap 3.3V regulator from flytron.com
http://flytron.com/camera-transmitte...regulator.html
and a 5.8Ghz 200mw module without built-in regulator for half the price from foxtechfpv.com or rangevideo.com:
http://www.foxtechfpv.com/tx5823-200...ers-p-272.html
http://www.rangevideo.com/index.php?...roducts_id=217
cmanley_nl is online now Find More Posts by cmanley_nl
Old Aug 29, 2012, 03:52 PM
Joined Aug 2012
Trader Rating: 0
Thx for the info!
noupi is offline Find More Posts by noupi
Old Jun 06, 2013, 01:13 AM
Canada, BC, Bowen Island
Joined Sep 2012
Trader Rating: 0
Awesome! Double thanks
featherodd is offline Find More Posts by featherodd
Old Jun 06, 2013, 05:53 AM
Unregistered User
cmanley_nl's Avatar
The Netherlands
Joined Jul 2010
Trader Rating: 0
For those looking for a small PCB board for the 200mw module, you can buy one here:
http://www.eyefly.info/index.php?rou...product_id=113
I'm not sure if it has a voltage step down on it though, so you'll need to ask them.
B.t.w. you can order the modules from Boscam:
http://www.boscamhobby.com/
Old Dec 24, 2013, 01:49 PM
United States, MI, Flint
Joined Mar 2013
Trader Rating: 0
I have one but the antenna pad is burned up, other than that it works fine, about 100 yard range with out antenna
mike300z is offline Find More Posts by mike300z
Old Aug 22, 2014, 04:18 AM
Joined Feb 2008
Trader Rating: 1
I got one of these, and as you all know the instructions and support are a bit lacking to say it kindly. I'm sure many of you know what you're doing, but I don't : (
Can anyone help me sort out how to select channels?
This is what the fpvhobby page says:
Channels selection are below:
Ch1 pin + Ch2 pin + Ch3 pin connect to ground (Channel 1 - 5.705 gHz)
Ch2 pin + Ch3 pin connect to ground (Channel 2 - 5.685 gHz)
Ch1 pin + Ch3 pin connect to ground (Channel 3 - 5.665 gHz)
Ch1 pin + Ch2 pin connect to ground (Channel 5 - 5.885 gHz)
Ch3 pin connect to ground (Channel 4 - 5.645 gHz)
Ch2 pin connect to ground (Channel 6 - 5.905 gHz)
Ch1 pin connect to ground (Channel 7 - 5.925 gHz)
DEFAULT - no connect to ground (Channel 8 - 5.945 gHz)
So do I need to solder the indicated pins to something? I'm not even sure where to find these pins.
Can anyone give me a few pointers here.
Thanks in advance,
-Dax
Daxophone is offline Find More Posts by Daxophone
Old Aug 23, 2014, 01:21 PM
Joined Feb 2008
Trader Rating: 1
Hate to bump myself but I'm sure someone here must know how to set the channel on this little Tx?
I got my tool set ready and am brushed up on my soldering.
Old Aug 24, 2014, 09:01 AM
Joined Feb 2008
Trader Rating: 1
Aha! Never mind. I figured it out by staring at the photo a little longer. /:
Old Aug 30, 2014, 10:34 AM
Joined Feb 2008
Trader Rating: 1
In the picture I posted previously above, according to the wring diagram power goes into the tx and then right back out -from the same terminal-.
Am I supposed to solder two wires to that terminal or can I just run one wire directly from the battery to both the tx and the cam?
I'm not too confident in my soldering skills to be doing two wires on the same tiny terminal for Christ's sake!!
Yippee! Parkzone Ultra Micro FPV - 5.8ghz 200mw FPVhobby TX - 40g without lipo's :D chancesAU FPV Equipment 2050 Nov 21, 2014 04:09 PM
Discussion 5.8 ghz 200mW Video Tx/Rx Tips schraut5 FPV Talk 38 Feb 01, 2012 01:31 AM
Sold Hobby King 5.8 GHz 200mW video tx/rx combo w/patch. ptuxbury FPV Equipment (FS/W) 5 Oct 21, 2011 03:26 PM
Discussion Burned 5.8 Ghz 500mWt transmitter from fpvhobby.com kedrikov FPV Talk 11 Oct 13, 2011 08:27 AM
Discussion 5.8 ghz 200mW Video Tx/Rx wire Question RedRanger FPV Talk 2 Jul 23, 2011 10:57 PM
