Old Feb 10, 2015, 12:13 PM
degreen60 is offline
Find More Posts by degreen60
Bloomfield, IN
Joined Nov 2006
Originally Posted by The Tellurian View Post
It should make a difference of perhaps 20-25 seconds glide rather than 15 but you'll need to try it for yourself to confirm. Use clear tape and you wont need to repaint.
Post a vid.
Richard
ps nice V2 actually it looks like a MX
I will fly it a few times like it is then cover the straight edges of the wing and tail with tape and also fill the curved edges with lightweight spackling. Then I will compare the flights.
degreen60 is offline Find More Posts by degreen60
Old Feb 10, 2015, 01:42 PM
Bloomfield, IN
Joined Nov 2006
I launched the Natter a couple of times today but instead of flying it wants to float down like a parachute. It floated so slow the controls had no affect because no air was flowing over them. I will try adding some weight to the nose. I want it to slightly dive nose down at peek of launch.
Old Feb 12, 2015, 02:03 PM
Bloomfield, IN
Joined Nov 2006
I did not like to way the nose looked on the ME-163. I cut the top off a bottle and slid it on the front of the ME-163. I think it looks better.
Old Feb 16, 2015, 11:03 AM
Bloomfield, IN
Joined Nov 2006
I installed a parachute in the Natter so it will always land soft even if I can not get it to glide. I finished painting. If I can not ever get it to glide I will remove all servos except the one for the parachute.
Old Feb 16, 2015, 11:13 AM
Thomas B. is online now
Find More Posts by Thomas B.
scratchbuilder
Thomas B.'s Avatar
Germany, Nordrhein-Westfalen, Cologne
Joined Mar 2012
It looks really dangerous!
Thomas B. is online now Find More Posts by Thomas B.
Old Feb 25, 2015, 09:42 AM
dankar04 is offline
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
Very cool and looks great.
dankar04 is offline Find More Posts by dankar04
Old Apr 02, 2015, 06:12 AM
Bloomfield, IN
Joined Nov 2006
The ME-163 blew up on the launch pad. The bottom bottle split almost the full length of the bottle at about 100 pounds. I was going for 140 pounds. Glad I put the fuselage top on with shipping tape, made it easy to remove it. When I make another one I am going to wrap duck tape around the bottles to reinforce them.
Old Apr 04, 2015, 03:35 PM
qwerty_2008 is offline
Find More Posts by qwerty_2008
Post Captian
qwerty_2008's Avatar
United States, CA, El Mirage
Joined Sep 2013
Originally Posted by Thomas B. View Post
I guess 40 - 60m. It would be a way to launch dlgs if you find a way to throw off the bottle.
I have seen a simple method of jettisoning boosters for water rockets. The booster is connected to the first stage via wire pins that fit into tubes, if the pins are mounted to the rocket itself they would be pointing down and if they are mounted to the booster they point up. When the boosters are producing thrust the pins are held in the tubes by the upwards pressure then when the boosters are no longer producing thrust they simply fall off. I see no reason this wouldn't work for your application.
Lextin.
qwerty_2008 is offline Find More Posts by qwerty_2008
Old Apr 05, 2015, 04:32 AM
scratchbuilder
Thomas B.'s Avatar
Joined Mar 2012
That is definitely worth a try. Thanks!
Old Apr 14, 2015, 05:32 AM
Bloomfield, IN
Joined Nov 2006
I rebuilt the ME-163. The rocker motor end of the 163 is a the top half of a Sprite bottle glued on a standard 2 liter bottle. I reinforced the joint with duck tape. When I charged the 163 the glue joint let go and it just ripped the duck tape apart. I reinforced this joint with clear shipping tape on the first 163 and the joint held. I will be using clear shipping to reinforce now instead of duck tape.
Old May 12, 2015, 08:17 AM
scratchbuilder
Thomas B.'s Avatar
Joined Mar 2012
New Glider:
Wasserraketen - Flugzeug 3.Generation (1 min 10 sec)
Launch pressure is around 80psi, flight time 20 - 25 seconds.
It will be a free download plan on Modell-Aviator.de in summer.
Old May 12, 2015, 10:00 AM
The Tellurian is offline
Find More Posts by The Tellurian
St Catharines Canada
Joined May 2002
Hey thats just gorgeous! You also did a great job of landing it in that tiny courtyard. Please post here when the plans are available.
Richard
The Tellurian is offline Find More Posts by The Tellurian
Old May 29, 2015, 07:53 AM
scratchbuilder
Thomas B.'s Avatar
Joined Mar 2012
Another video:
Zisch 3 Water Shuttle (0 min 36 sec)
Old Jun 19, 2015, 02:52 PM
scratchbuilder
Thomas B.'s Avatar
Joined Mar 2012
Zisch 3 build log
Here is the build log and download link for my new water rocket glider Zisch 3:
http://www.rcgroups.com/forums/showt...4#post31940181
For Sale full carbon wing for s8E/p rocket glider krzysztof wrobel Aircraft - Sailplanes (FS/W) 5 Jul 14, 2014 12:37 PM
Discussion Need recommendation for NAR RCBG Radio (Boost Glider / Rocket Glider) majordude Radios 5 Feb 20, 2014 06:49 PM
Sold Cuda rocket glider rcdude01 Aircraft - Sailplanes (FS/W) 4 Dec 27, 2013 05:55 PM
Discussion Need radio for 1m slope soarers and rocket Boost Gliders majordude Radios 2 Nov 19, 2013 03:53 PM
