Old Apr 07, 2014, 06:35 AM
rob737 is online now
Find More Posts by rob737
United States, CT, Guilford
Joined Nov 2008
Help!
unable to get cox motors to run
hi guys,
I started with cox motors and control line many years ago (flying guillows kits). over the last year or so I've picked up a few new motors and can only get my throttle version one to run. the other three sure starts only fire and run in a brief spurt....this includes the motor on a new/old production cox pt19 I picked up on ebay. using a new hobbico 1.5v battery, new cox super power fuel, and have checked glow plugs, switched fuel tanks and lines, and everything else I can think of. the manuals say to start the starting process with the valve open four turns, and I've tried a turn or two in either direction but still only get the same brief spurts of run time.
this brings back a lot of memories of fooling with these motors! I think back in the day I only had one (our of several) that would run reliably. nice to see how easy things have become these days with our electric set ups....
anyways, if anybody has any ideas i'd love to hear them! thanks for your help!
rob737 is online now Find More Posts by rob737
Old Apr 07, 2014, 07:55 AM
aspeed is offline
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
Usually the reeds gets dried castor on, and don't seal. This can be remedied by dribbling a couple of drops of fuel through the hole in the backplate. Sometimes the pickup tubing gets real hard and cracks, or the needle valve and the little hole get clogged. If you don't want to take the motor apart, you can fill the tank and plug one filler hole and squirt fuel though with a bit of pressure and repeat with the needle out. I would just disassemble it and check everything, being careful of the backplate gasket, and checking the O ring. Having said that, it usually takes a few runs off of prime to get them feeding right. 4 turns doesn't sound outrageous.
aspeed is offline Find More Posts by aspeed
Old Apr 07, 2014, 08:31 AM
Joined Nov 2008
so, disassemble, check, clean? didn't consider this since the motors were new (although possibly many years old) but it can't hurt. thanks for the suggestion, i'll try this later today. funny, the only one that runs is new production so you may be on to something as far as the others being gunked up.
thanks.....rob
Old Apr 07, 2014, 10:32 AM
Sonsight is offline
Find More Posts by Sonsight
Sonsight's Avatar
United States, AR, Cabot
Joined Aug 2004
I recall my Cox .049's needed 3 1/2 turns out to start.
Sonsight is offline Find More Posts by Sonsight
Old Apr 08, 2014, 04:32 PM
gettinout is offline
Find More Posts by gettinout
Joined Jan 2004
Rob, I'm not sure if you've heard or read, but the new Cox fuel being sold by Tower Hobbies is terrible for the Cox engines. The Cox engines need at least 20% castor oil in them. The new Cox fuel sold by Tower only has 1.8% castor in it. I'd add a good bit of castor to your bottle, or just get some fuel with a guarantted castor content of 20% or better.
Mark
gettinout is offline Find More Posts by gettinout
Old Apr 08, 2014, 06:17 PM
pilatus mike is offline
Find More Posts by pilatus mike
pilatus mike's Avatar
London, England
Joined Apr 2007
I would agree, 20% castor is a must. I use Model Technics GN25 Nitro Mix - contains 20% castor oil with nitromethane only as the power and tractability additive. This is the range demanded by the traditional modeller and is well tried and tested.
pilatus mike is offline Find More Posts by pilatus mike
Old Apr 09, 2014, 05:06 AM
Joined Nov 2008
wow, I had no idea about this fuel! I thought by buying cox I was getting the right stuff. i'll look for what you guys have recommended (I think sig makes it). thanks.....rob
Old Apr 09, 2014, 10:34 AM
RV Winkle is offline
Find More Posts by RV Winkle
Sailaire brethren
United States, KY, Bowling Green
Joined Aug 2013
Thanks for info on Cox fuel. Pretty sure in the dark ages it had the higher castor amount. any idea on why the change?
RV Winkle is offline Find More Posts by RV Winkle
Old Apr 09, 2014, 12:45 PM
Joined Nov 2008
I found sig "champion 25," here's the formula:
25% Nitromethane
20% Lubricating Oils
(1/2 Castor, 1/2 Klotz)
I seem to remember using this a few years ago and getting decent runs (at least on the bench).
it's not entirely 20% castor but would this be ok?
thanks again.........rob
Old Apr 09, 2014, 02:36 PM
Amp Abuser is online now
Find More Posts by Amp Abuser
Amp Abuser's Avatar
Joined Dec 2007
Just make sure you have a strong 1.5v current these cox glow elements tend to need more than a standard glow plug on 1.2v nicad type cell. That and a electric starter should help even the most fussy engine.
Amp Abuser is online now Find More Posts by Amp Abuser
Old Apr 09, 2014, 02:55 PM
combatpigg is offline
Find More Posts by combatpigg
Joined Feb 2011
Hoppes #9 gun cleaning solvent and a basic gun cleaning kit are good to have for .049 maintenance.
Plastic bristle bore brushes and rags come in the kit.
A cheap plastic jeweler's lens is an interesting "tool" to have. Not so much a tool, but it will reveal flaws in small parts that the naked eye can't.
Also a Monoject 2 oz veterinary syringe with a short piece of 3/32" brass tubing pressed into the tip is useful for fueling, blowing out / sucking out / troubleshooting fuel lines and "pressure washing" dirty engines at the field.
most of my problems with reedies have been grass seed and hairs collecting at the intake screen or at the reed. The reed has to be free to bounce back and forth inside it's little enclosure and it doesn't take much foreign matter to disrupt it's movement.
combatpigg is offline Find More Posts by combatpigg
Old Apr 09, 2014, 05:47 PM
ahrma_581 is offline
Find More Posts by ahrma_581
Ricinus communis
ahrma_581's Avatar
United States, AZ, Ajo
Joined Jun 2012
+1
It's surprising how stuff can find its way between the reed and seat but not find its way back out. Doesn't take but a small piece of schmutz to keep the reed from seating and she no run....
ahrma_581 is offline Find More Posts by ahrma_581
Old Apr 09, 2014, 07:33 PM
Andrew0820 is offline
Find More Posts by Andrew0820
Western KY
Joined Sep 2003
............most of my problems with reedies have been grass seed and hairs collecting at the intake screen or at the reed. The reed has to be free to bounce back and forth inside it's little enclosure and it doesn't take much foreign matter to disrupt it's movement.
I've had grass seed problems, too. Hard to figure how a seed can work it's way up the intake groove in the back plate, down the venturi and lodge under the reed.
Andrew0820 is offline Find More Posts by Andrew0820
Old Apr 09, 2014, 10:19 PM
hllywdb is offline
Find More Posts by hllywdb
Joined Jan 2013
I always figured the flight goblins put them there. I've flown the old golden bees which had the screen over the intake on a concrete parking lot and still got stuff in the reed. I don't think even a K&N filter would stop it. So I just figured it was the same goblins from the old twilight zone episode with William Shatner that did it.
hllywdb is offline Find More Posts by hllywdb
Old Apr 11, 2014, 01:36 AM
KnifeEdge51 is online now
Find More Posts by KnifeEdge51
central AZ
Joined May 2002
K&N filters are terrible for anything other than performance engines. They let way too much stuff through when compared to traditional paper or foam filters, IMO. Sure they breath better, meaning better performance, but unless you're ready to do a rebuild (as most race teams are), then you're not likely doing yourself any favors using them. Just an FYI.
KnifeEdge51 is online now Find More Posts by KnifeEdge51
For Sale Never Run Cox E-Z Bee Engine stompjrkz400 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Dec 25, 2014 06:29 PM
Help! ESC getting hot - motor's not even running avt Multirotor Electronics 3 May 22, 2014 08:35 PM
Help! Unable to get Witespy MWC to activate motors/esc mysql101 Multirotor Electronics 2 Nov 29, 2013 06:25 AM
For Sale Custom rc cox gas car running chassis reptileman Cars - Trucks and Parts (FS/W) 1 Sep 27, 2013 12:11 PM
Help! Unable to get the motors to start rcoeng Multirotor Electronics 4 Jan 12, 2013 05:13 PM
