Old Jun 23, 2013, 12:20 PM
Liverpool, England
Joined Jan 2005
Build Log
Avro Lancaster BIII (Special)
Hi Everyone,
With the Henschel finished its time to start my next project, as its the 75th anniversary year of Operation Chastise I am going to fulfill my long term ambition of building a Lanc
Since a youngster I have dreamed about building a large scale Lancaster so this is more of a quest for me. Of course this plane has been modelled many times before so its unsual for me as I normally like to pick obscure subjects. So I will make it a little unusual, of course it will drop the upkeep bomb but if I can afford to I intend to put a camera in the bomb aimers position with an FPV headset to give someone the pleasure of aiming the bomb and releasing it!
Anyway on with the show, here are the specs -
Scale - 1/10th
Wing Span - 3.1m (122in)
Dihedral - 5.75'
Incidence - 3.5'
Motors - 4 x 400kv
Props - 4 x 16x10 3 blade
Batteries - 4 x 6s 4000Mah
I downloaded a CAD drawing from the net, which isnt very good, and purchased an excellent Airfix 1/72nd scale Dambusters model.
Wireframe and basic layout is complete but some questions straight away. Wing incidence is incredibly high on the model and on at least one image of a kit plan at over 5.5' I have reduced this a little but any comments? In addition there is positive incidence on the H stab on the same kit plan this is at 2.5' again I have reduced this to 1' as a pure guess but any comments would be appreciated
Havent stated a target weight as I never get it right, construction will be built up balsa with glass fibre mouldings for cowls etc
Fuse will be split in two for ease of transport and the outer wings including outer nacelles will also remove
Batteries will be housed within the nacelles
I reckon I have two months worth of drawing before I can start building, total build time will be 18 months
Any advice, comments are always welcome
heli_madken is offline Find More Posts by heli_madken
Old Jun 23, 2013, 12:35 PM
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Man, is this going to be great or what.
J
J Morgan is offline Find More Posts by J Morgan
Latest blog entry: OV-10A Bronco from Palmer Plans
Old Jun 23, 2013, 02:16 PM
JustFlying
rebell's Avatar
Joined Dec 2005
Every time I see a big scale model Lancaster I think of building one. Maybe, some day when I am retired, I will build one.
rebell is offline Find More Posts by rebell
Old Jun 23, 2013, 03:58 PM
Ducky22's Avatar
Canada, ON, Mississauga
Joined Apr 2011
Another one to follow...love this plane!
Ducky22 is offline Find More Posts by Ducky22
Old Jun 24, 2013, 12:01 AM
Joined Feb 2012
Cool !! I happen to know a dude who flew Lancs..
jt
jpt62 is offline Find More Posts by jpt62
Old Jun 24, 2013, 03:42 AM
Registered Slopeaphile
awmeade's Avatar
S-u-A, UK.
Joined Jan 2003
Save some months and do a Nijhuis one
http://www.tonynijhuisdesigns.co.uk/Lancaster134.htm
awmeade is offline Find More Posts by awmeade
Old Jun 24, 2013, 04:55 AM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
When I start something fairly big, my first consideration is, how do I transport it ?
If you have a limitation on what your car can take, (you mention various splits), then I would recommend designing that into your model right up front.
Also consider just were the batteries, and ESC's will go for reasonably easy access including the access hatches.
One of the modeling 'Laws' is, 'Whatever you make difficult to access, will be the first thing to go wrong when at the field'.
I haven't gone quite that big yet, but here's some pictures of where I have designed splits to aid transport.
eflightray is online now Find More Posts by eflightray
Old Jun 24, 2013, 07:09 AM
Liverpool, England
Joined Jan 2005
Thanks eflightray, beautiful models and great ideas, hope you dont go round corners too fast when loaded up!
Nah, a good part of the fun for me is the design, spend hours thinking about it as well as drawing which is all part of the recreation to me
Cheers, Ken
Old Jun 24, 2013, 08:19 AM
raipe's Avatar
Finland
Joined Oct 2008
So cool! I lurcked around for your fabulous Henschel build and am still overwhelmed by that. Got to follow this one too
raipe
raipe is online now Find More Posts by raipe
Old Jun 24, 2013, 08:39 AM
awmeade's Avatar
S-u-A, UK.
Joined Jan 2003
Cheers, Ken
Fair enough - can't beat cracking your own difficult nuts I prefer to fly - even though I'm a Design Engineer!
Old Jun 24, 2013, 09:38 AM
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
I too will be watching this build very closely! I just saw a Lancaster flying at the Hamilton Air Show on July 15th. It was followed by the only flying Mosquito, a pair of Hurricanes and a Spitfire Mk XIII!! Way cool to see and hear.
The real Lancaster does have an amazing amount of dihedral, some of it appears to be the wings actual build making it look far more than it actually is. The Mosquito is similar, the bottom of the wing tapers quickly from fuse to tip, but that's not the true dihedral.
Some one out there likely has more precise plans or actual Lanc drawings to confirm your build.
The Lancaster is a very impressive plane in the air, unloaded as it flys in airshows, they throw it around like a big fighter!! It appeared that only the mosquito had to fly at reduced power (nose up) to maintain position on the Lanc, the Hurry's and Spit seemed to be working just a little to keep up to the Lanc cruise.
As Dag would say "Rock on". Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Jun 24, 2013, 09:47 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I can see madken's point of view.
Total scratch building can be a real brain teaser, (and at times totally frustrating), but the sense of achievement on the first successful flight is way beyond what a kit or plan can give.
My B-17 and B-25 were totally scratch built, based on 3-views and plastic models, scaled up to a size I liked and roughly drafted out on paper.
My Sunderland and Spitfire, (Spitfire in the back of the car), were based on existing plans, but built from Depron not the original balsa structures. The enjoyment there came from still needing a lot of thought and designing the structure to suit the material.
The Spitfire is actually based on the Nijhuis balsa and IC powered Spitfire plan, (well it was free in one of the magazines ). I just wanted to prove to myself I could build it lighter in Depron. The magazine article quoted an expected 15Lbs build, mine came out at half the weight including the batteries.
That's where the excitement of scratch building comes from, achieving something no one else has built.
Good luck with the build madken, when, (if ?), I ever have a disaster with the B-17, a Lancaster will replace it. (A scratch built Lancaster ).
Old Jun 24, 2013, 12:58 PM
Liverpool, England
Joined Jan 2005
Next stage is to start working out the relevant positions of the main components, I really would like to get both 4000Mah Lipo's within the main nacelle so that the loads are directly over the undercarriage rather than having any batteries in the outboard nacelles, it looks tight but the nacelles are quite square in section so it might work.
Scale wheels are closer to 7" shown are 6" which only just fit so I may have something wrong here in terms of the depth of the nacelle, when extended the oleos slant backwards by 5'
Next stage is to position the main tubular spar so its close to the retract so I can transfer loads to it
Question are 4000Mah batteries over the top? do you think 3300Mah would work as there are four engines
Old Jun 24, 2013, 02:41 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I use two 3s 4000mAh packs in my B-17, even with a quite long flight I rarely put as much as 2000mAh back.
One pack powers the inner pair, and one the outer pair of motors.
All my ESC's and batteries are in the fuselage, the wings plug in and then the fun of connecting the 6 ESC connector each side starts . The only other connections are the aileron servos. My retracts are scratch built and operated by torque tube from a central servo.
Old Jun 24, 2013, 02:44 PM
Übung macht den Meister..
Deuce's Avatar
United States, OR, Fairview
Joined Jul 2006
Other folk more knowledgable than I may chime in (please!), but I understand the incidences of wing and horizontal are probably correct. I believe the Lancaster flies with a noticeable nose-down attitude.
James
Deuce is offline Find More Posts by Deuce
Alert Important Scale Details for the Avro Lancaster vonJaerschky Scale Kit/Scratch Built 7 Mar 25, 2014 02:15 AM
Avro lancaster 3-views? Paul Penney Electric Plane Talk 8 Oct 13, 2009 07:48 AM
Avro Lancaster Bomber - PRE-Flight RC Sim New Plane pingprime Simulators 0 Dec 19, 2004 05:38 AM
Avro Lancaster faust Foamies (Kits) 4 Oct 03, 2004 03:07 PM
"Fund my t--b--e" sale : Avro Lancaster Atindra Aircraft - Electric - Airplanes (FS/W) 6 Nov 21, 2003 09:20 PM
