Old Sep 17, 2014, 02:49 PM
United States, NY, Champlain
Joined Mar 2013
Anybody know what's the motor shaft diameter?
thx
littleduffman is offline Find More Posts by littleduffman
Old Sep 20, 2014, 10:03 AM
Joined Sep 2014
Hi,
I have a problem with my transmission. The cup on the side of the motor (left when facing forward) has some play. I tried to fasten the screw which is holding this cup (inside the differential) but it's already very thight.
It's very annoying since the car is vibrating as hell when making some speed because of this loose cup. Is there any other thing I can do other than buying a new differential (like this: http://www.banggood.com/Wltoys-L959-...5-p-75973.html). Thanks
wouter205 is offline Find More Posts by wouter205
Old Sep 20, 2014, 08:06 PM
Joined Sep 2014
L979 motor?
I have a wltoys L979 and my motor stopped working. I was wondering what motor the L979 has on it. I have look for 979-33 but have found nothing. Does anyone know if the L979, L969, and L959 run the same motor?
Tatumboy08 is offline Find More Posts by Tatumboy08
Old Sep 22, 2014, 11:55 PM
Joined Apr 2014
Yes they are the same cars. Only difference are wheels and body setup.
WLtoys-L959-L969-RC-Car-Spare-Parts-Motor-L959-33
Search for L959 when looking for pars and you will get more options. You can also order the motor for A959/969/979 if you change the pinion.
HeliViking is offline Find More Posts by HeliViking
Old Sep 22, 2014, 11:56 PM
Joined Apr 2014
thx
2mm
Old Sep 27, 2014, 01:15 PM
Joined Dec 2010
Hi all!
I'm new here, i try to find something like my problem but couldn't
I have L202, then i received was very happy, but on next day ESC on my buggy burned
I order new one. Connected it. Connected battery and cooler starts to spin, but switch was switched off.
Links to youtube:
L202 ESC problem (1 min 58 sec)
Switch buggy on, it runs. But in opposite directions.
In manual is written then you pull trigger it runs forward and the push it run backward.
In my case then i pull it runs backward, push - forward.
Where could be problem?
Snufkin is offline Find More Posts by Snufkin
Old Sep 28, 2014, 09:25 PM
Aaron qin's Avatar
China, Guangdong
Joined Oct 2011
Hi Snufkin, switch any two wires of the three motor wires connected with ESC, you can get the direction right.
Aaron qin is offline Find More Posts by Aaron qin
Site Sponsor
Old Oct 01, 2014, 05:51 PM
Joined Sep 2014
I just got this battery for my L202....and wow, what a difference! It runs at least 2 times longer than with the original battery and better performance... it perfectly fits into the battery pocket once you shave the weird plastic things....you can cut them easily with pliers.
hokkabaz is offline Find More Posts by hokkabaz
Old Oct 02, 2014, 06:54 PM
Joined Mar 2013
Thanks a lot
Old Oct 08, 2014, 05:08 PM
Joined Oct 2014
Hi, have anyone tried the WLToys A959? I like the 4WD transmission and the motor looks more powerful. But A959 is smaller (1/18)
I didn't know that the A959 motor fits in the L959 car. Can you tell the difference changing the motor?
gonz147 is offline Find More Posts by gonz147
Old Oct 09, 2014, 03:18 PM
SeByDocKy's Avatar
France, PACA, La Valette-du-Var
Joined Dec 2012
You will need also to exchange pinions too
SeByDocKy is online now Find More Posts by SeByDocKy
Old Oct 14, 2014, 10:15 PM
nizzamms's Avatar
Malaysia, Johor, Johor Bahru
Joined Oct 2007
hi i just replace my speed reduction gear, its located between motor pinion and diffrential gear, do i need to put lot of grease just like the video on the first page or just ignore it ...
if i wanna put grease, what type grease is suitable for plastic gears?
nizzamms is offline Find More Posts by nizzamms
Old Oct 18, 2014, 01:39 PM
I dont like crashes!
Germany, BY, M
Joined Jul 2013
Replacement parts from Europe or Germany?
SilbernerSurfer is online now Find More Posts by SilbernerSurfer
Mini-Review WLtoys V912 4-Channel Fixed Pitch Helicopter Mini-Review FyreSG Micro Helis 7648 Yesterday 07:45 PM
Mini-Review MJX F45 VS F46 ,WLtoys V912 VS V913 Aaron qin Micro Helis 127 Sep 01, 2014 11:52 AM
Mini-Review WLtoys V959 Quad (with Video Recording Function) Mini-Review FyreSG Mini Multirotors 1313 Aug 11, 2014 08:48 PM
Data HiSKY FBL100 / Turnigy FBL100 / WLToys V922 vs. mCP X Parts Compatibility sparkyjohn Micro Helis 101 May 31, 2014 11:58 AM
Discussion WLtoys V949 UFO Quad fierce Hot Online Deals 5 Jan 09, 2013 09:07 AM
