Old Jul 14, 2012, 02:55 PM
Joined Jul 2012
Question
Taking Off/Landing on Dirt Baseball Diamond
I've been taking off and landing my older plane on a dirt baseball diamond. Is it possible for the dirt to get sucked into the inside of the plane or the motor and mess something up? I havn't had any problems so far, but I just want to make sure before I use my nicer plane on dirt.
Thanks!
Edit: Also, has anyone here flown their planes on a football field? If so, do the goal posts get in the way?
ClevelandBaller is offline Find More Posts by ClevelandBaller
Old Jul 14, 2012, 03:13 PM
Gilbert AZ
United States, AZ, Gilbert
Joined May 2012
Yes I fly Large Electric airplanes 6lb or more from a compact dirt runway without any problems. If I crash nose first or nose over the airplane during a landing I would blow it out with compress PC keyboard cleaner air and if required disassemble the motor and clean it out more. Also lube the bearings.
Yes I have flow from football fields. Just avoid flying into the goal posts.
azflyingguy is offline Find More Posts by azflyingguy
Old Jul 14, 2012, 03:18 PM
Joined Jul 2012
Ok thanks!
Old Jul 14, 2012, 03:26 PM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Flying can be carried out in most places, even on a beach, (sand and salt ), but there is always a risk.
As for goal posts, flood lighting towers, trees, bushes, even the ground itself, can occasionally move when you least expect it, and generally right in front of you model. They like to play games with us.
Nice new models always fly better after they have a few dings, dents, scratches etc, It's just something we get used to, (or give up and assemble plastic kits and keep them in display cases).
Enjoy flying.
eflightray is online now Find More Posts by eflightray
Old Jul 14, 2012, 10:54 PM
USA, NJ, South Plainfield
Joined Sep 2008
I take off and land from an infield alot, only problem I ever had was a retract get jammed with loose dirt, just landed gear up in the grass. Cleaned it out later that day and haven't had a problem with it since.
jughandle is online now Find More Posts by jughandle
Old Jul 15, 2012, 04:28 AM
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
Infields work well for taking off. They are especially suitable in the sports off season when they are not being groomed regularly and have a chance to harden. This greatly reduces the amount of loose material that can be attracted into a motor.
whitecrest is online now Find More Posts by whitecrest
Discussion f35 vertical take off , vertical landing f35vertical Electric Ducted Fan Jet Talk 22 Oct 14, 2012 10:39 AM
Discussion f35 vertical take off , vertical landing f35vertical Electric Ducted Fan Jet Talk 13 Jun 21, 2012 03:13 PM
Discussion f35 vertical take off, vertical landing. f35vertical Electric Motor Design and Construction 6 May 30, 2012 03:20 AM
Help! Vertical take off and landing edf jet pulsery2k1 VTOLs 14 May 10, 2012 09:43 PM
Question Power gliders and water landing & take off Sculptor 3D Foamies 0 Mar 30, 2012 05:23 PM
