Old Mar 01, 2015, 06:51 PM
Joined Apr 2010
Landing on tarmac
Hi,
My primary site is an RC airfield, it has a really nice tarmac landing strip, but no grass...
I've been flying a Multiplex Solius there and use clear plastic vinyl coating for the underbelly and on the wingtips to protect it when I land.
I recently purchased a high end scale LET ASW28-- any tips on how to protect the wings on landing? Been thinking about some small winglet wheels but not sure how that will affect gliding performance.
Chief
BHChieftain is online now Find More Posts by BHChieftain
Old Mar 01, 2015, 09:01 PM
Old Prop Buster
Sir Dumb Thumb's Avatar
United States, CA, Grass Valley
Joined Dec 2009
If there is dirt on the edge of the runway I would choose that over pavement, I would think wheels would create a lot of drag. I would probably choose a hard plastic skid. Maybe make one, you could heat and bend it to shape. I would probably tape it on well first for a trail and then gorilla glue or epoxy it on when I was satisfied. Maybe someone else has a better idea, I hope. What material is the wing made out of?
Gary
Sir Dumb Thumb is offline Find More Posts by Sir Dumb Thumb
Old Mar 01, 2015, 11:48 PM
Joined Apr 2010
Gary
The wing is sheeted with a white ultracoat covering. I would be taping the wheel on, I could tape a skid as well.
Chief
Old Mar 02, 2015, 12:01 AM
Be an organ donor
Little Rock, AR. U.S.A via U.K
Joined May 2004
Have you tried going to the Scale Sailplane posting and ask there? How big is yourASW28? How are you launching it?
kwmtrubrit is offline Find More Posts by kwmtrubrit
Old Mar 02, 2015, 09:23 AM
Supersonic Engineering
GordonTarling's Avatar
UK, Greater London, Uxbridge
Joined Mar 2001
A simple bent wire skid will protect the wingtips and add very little drag. You could even make them removable if you needed to.
GordonTarling is offline Find More Posts by GordonTarling
Old Mar 02, 2015, 11:06 AM
Old Prop Buster
Joined Dec 2009
Bent wire sounds better than skid in my book.
Gary
Old Mar 02, 2015, 11:45 AM
AMA7224 LSF1832
Leadchucker's Avatar
United States, DE, Seaford
Joined Sep 2008
Maybe you could use these:
http://www.espritmodel.com/wing-tip-skids-3.aspx
Leadchucker is offline Find More Posts by Leadchucker
Latest blog entry: SUSA 4 metre Eagle for ALES/F5J
Old Mar 02, 2015, 11:57 AM
Spool 'er up!
Paul1PA's Avatar
United States, FL, Oxford
Joined Mar 2010
Originally Posted by Leadchucker View Post
Hobby King also offers wing skids. CLICK HERE to view the three different styles.
Paul1PA is offline Find More Posts by Paul1PA
Old Mar 02, 2015, 01:42 PM
so. cal.
Joined Jan 2006
Nothing wrong with old Goldberg tip skids, they get ground down, just replace em.
s2000 is online now Find More Posts by s2000
Old Mar 02, 2015, 08:53 PM
Joined Apr 2010
Thanks for the tips (no pun intended...)
Chief
Old Mar 04, 2015, 08:42 PM
IT'S NOSE HEAVY!!!!!!!
cityevader's Avatar
United States, CA, San Jose
Joined Mar 2012
Obtain a quality IPA in a can (there's a few out there), drink entire contents in order to empty said can. Slice up the can carefully, tape to plane in appropriate areas, fly.
Avoid crappy beer, as somehow it negatively affects the aluminum.
cityevader is offline Find More Posts by cityevader
Old Mar 04, 2015, 09:53 PM
doc993's Avatar
United States, WI, Stoddard
Joined Dec 2009
Check out ultimate two's threads he fly's off pavement and makes landing skids from foam.
doc993 is offline Find More Posts by doc993
Build Log HPI Baja 5B "TARMAC" or DIY Freefly Tero yannkibongui.com Electric Power Cars 8 Feb 27, 2015 08:00 AM
Discussion Looking for a concrete or tarmac Runway trobi Australia 19 Dec 22, 2013 06:37 PM
Help! Ways to protect Hotliner when landing on Tarmac. George Rc High Performance 8 Oct 14, 2012 12:56 PM
Discussion Baja on Tarmac oval track goddamnswede Large Scale Cars 0 Aug 15, 2007 01:36 AM
