Old Feb 12, 2015, 08:16 PM
Joined Sep 2014
Wiring Walkera RX1002 (Newb)
I recently purchased a Devo 10 and RX1002 (picture) pair, and have had problems finding documentation about the RX1002 and how to wire it. (T-Rex 450 FPV build, if it matters)
Primarily I've got 3 unanswered questions:
  1. The power plug on the RX1002 has a signal, ground and power. How do I use the signal wire? Is it RSSI? Input? Output? PWM? Analog out? (FWIW, I'm plenty literate in embedded electronics)
  2. What is the pinout for the servos on the RX1002? All of my servo connectors have plain rectangular connectors, so I'm clueless as to which side the notch should be on. Is the notch on the RX1002 the signal or the ground?
  3. I'm using 2x3S batteries, and need to run power to the following: The RX1002, Remzibi OSD (8-12V) board, Camera (5v), Video TX (8-12V with a Vout of Input - 0.5V), and the ESC My "best guess" on how to hook them up would be: Large 3S battery to ESC + Remzibi "ENG" telemetry input, and the smaller 3S battery to the Remzibi, the TX and a 5V voltage regulator (LM7805). The output of the LM7805 would go to the camera and the RX1002. The output of the TX will be unused. Is that sensible? Will I need any power filters?
Note: I may know embedded electronics, but I'm a newb to modern RC radios.
SvdSinner is offline Find More Posts by SvdSinner
Old Feb 13, 2015, 03:49 AM
Joined Dec 2011
1. It used for bind plug.
2. GND to outside.
vlad_vy is offline Find More Posts by vlad_vy
Old Feb 21, 2015, 09:41 AM
Joined Sep 2014
Thanks! That leaves me with only one unanswered question:
I'm 75% sure this is correct, but I'd love second person to confirm this is reasonable.
Mini-HowTo wiring naza v2 to rx1002 cingarelo Multirotor Electronics 0 Nov 13, 2013 07:12 AM
Sold Walkera Devo 10 (Flashed with Deviation 3.0) + rx1002 ummagawd Aircraft - General - Radio Equipment (FS/W) 0 Oct 10, 2013 02:38 AM
Wanted Walkera RX1201/RX1202/RX1002/RX801/RX802 RawmadeCF Aircraft - General - Radio Equipment (FS/W) 0 Jan 12, 2013 06:45 AM
Sold walkera rx1002 and castle airfield link - brandnew cb100 Aircraft - General - Radio Equipment (FS/W) 4 Dec 03, 2012 06:03 PM
Discussion Quadrino with Walkera Devo 10 and RX1002? IridiumFox Scratchbuilt Multirotors 1 Oct 01, 2012 09:33 AM
