Old Aug 13, 2014, 10:23 AM
Joined Jun 2013
Originally Posted by midelic View Post
PM to me your email....maybe you can finish it and test...spare me some time
what ? i still contact with you by email .
ok, go ahead , i will test code for you . i free time every night.
John michel is online now Find More Posts by John michel
Old Aug 13, 2014, 10:33 AM
midelic's Avatar
Joined Apr 2012
Sorry I have it......
midelic is online now Find More Posts by midelic
Latest blog entry: DIY FlySky RX ATTINY85/45
Old Aug 21, 2014, 01:07 AM
Joined Jun 2013
anyone use this ? http://www.hobbyking.com/hobbyking/s...mpatible_.html
Does it use CYRF6936 ? because I intend to buy it to use for DEVO 7 and also use it for some helicopter use protocol DSM2. .
connect pins communicate CYRF6936 to circuit Devo7 to use protocol Devo, and connect input PPM to output devo 7 to use protocol DSM2 . Because DEVO 7 don't support protocol DSM2 from deviation
I wonder : is it CYRF6936 , Right ? hope someone opened it .
Old Aug 22, 2014, 09:08 AM
Joined Jun 2013
well well, I think i find answer exactly
first , i worry it is CYRF69103,CYRF6940 ....
now . i will test firmware DSM2 of Midelic , Hope far range
Old Aug 24, 2014, 09:58 PM
We can rebuild it!
djdavies83's Avatar
United Kingdom, Wales, Swffryd
Joined Apr 2010
Hey John, what method did you use to remove that rf shield?
Also does anyone know a supply for the white pine connector on this PCB?
djdavies83 is offline Find More Posts by djdavies83
Old Aug 24, 2014, 11:08 PM
Joined Jun 2013
you can see it soldered 4 point , use device as photo bellow or if you don't have it , you have to move fast tip solder to remove 2 point before.
Pin connect is compatible TX tunigy9ch , Pin 3 VCC, pin 4 GND
Old Aug 25, 2014, 12:12 PM
Joined Jun 2013
@M
i just tested arduino protocol DSM2 ( main DEVO ) with main board blade 130x ( CYRF69103 ) , it still Bind ok
Old Aug 25, 2014, 01:16 PM
midelic's Avatar
Joined Apr 2012
Yes I know...it binds...i didn't have time to finish the code(not only finish ,need testing)....I still need to work...I work abroad outside of my country...I'll come back at the end on September.If you have coding skills you can finish it and test it......and I can add in multiprotocol.If not you wait for me to come back.
Old Aug 26, 2014, 03:22 AM
Austria
Joined Jan 2004
If I can ask ... where are you now ?
e_lm_70 is offline Find More Posts by e_lm_70
Old Aug 26, 2014, 03:55 AM
midelic's Avatar
Joined Apr 2012
In the Atlantic ocean around 150 miles from shore.... about 8 DEG South latitude and 13 DEG East longitude.......
Old Aug 26, 2014, 04:18 AM
Austria
Joined Jan 2004
In other words ... Angola off shore ... nice
Have a good work there
PS: You should have took some nice camera copter for take some video from there ... it would have been interesting to see
Old Aug 26, 2014, 04:21 AM
Joined Jun 2013
sound like a trip fishing interesting.
Old Aug 26, 2014, 04:39 AM
midelic's Avatar
Joined Apr 2012
I'm not allowed with lipo battery(or any battery) in the gas plant.....for camera you need special permit.......it will be "funny" playing with the copter around the gas flare.
Old Aug 26, 2014, 11:49 AM
We can rebuild it!
djdavies83's Avatar
Joined Apr 2010
Haha THERMAL LIFT!!!
Old Aug 27, 2014, 03:00 AM
SeByDocKy's Avatar
France, PACA, La Valette-du-Var
Joined Dec 2012
Whaooohhhh this thread is so great too !!!!!!
SeByDocKy is offline Find More Posts by SeByDocKy
Build Log RC Poyglot--Multiprotocol DIY TX iter DIY Electronics 136 Feb 18, 2015 02:06 PM
Discussion Cheap DIY radio - RX and TX modules e_lm_70 DIY Electronics 446 Feb 06, 2015 03:28 PM
Discussion Cheap & Easy - DIY openLRS/openLRSng - RX & TX modules e_lm_70 DIY Electronics 244 Feb 05, 2015 04:10 AM
Discussion DIY: HiSky HT8 External TX module (JR) for V922 and Taranis TX piotrkundu FrSky 1 May 04, 2014 10:18 PM
Discussion DIY Orange-tx-module-dsmx for Aurora 9x? Ashley123 Hitec/Multiplex USA 1 Feb 06, 2014 02:29 AM
