Old Aug 19, 2015, 08:14 PM
MrSatoV is online now
Find More Posts by MrSatoV
Trying to make sense of it all
MrSatoV's Avatar
Japan, Kanagawa Prefecture, Yokohama
Joined Oct 2009
Relationship between cells/volts and C rating
Is there a chart or something somewhere that shows power output, in terms of thrust maybe, for different cell batteries with different C ratings? More specifically, different cell counts for a given C rating. Like how much thrust was output using a 3S 35C battery compared to a 4S 35C battery.
Or, maybe something far less complicated. Someone could give their experience with it, both in terms of performance, as well as flight times.
Maybe the reason behind my question would help clarify what I'm looking for. I currently am using 3S 1500mAh 30C batteries, on a 250 using 2204 2300kv motors and 6045 props. I'm trying to figure out what 4S battery to get that would give more power, but as match my 3S batteries as close as possible in terms of weight, size, and flight times. I don't mind to lose a little flight time, and I know I'll have to end up with a little more weight, but I want to keep those losses to a minimum without ending up with too similar performance.
I see most racers - like at nationals - used 4S 60C and higher batteries - FinalGlide had 70C? I'm not that level pilot, so I'm thinking that C rating isn't necessary yet for me, and a lower C means a lower cost, which is also important to me.
MrSatoV is online now Find More Posts by MrSatoV
Old Aug 19, 2015, 08:16 PM
MrSatoV's Avatar
Joined Oct 2009
Weird, when I searched I didn't find threads about this topic, which I thought couldn't be right. Turns out, it isn't right. No sooner I hit post, I see the "similar threads" section below, and yep, the info is already there, just like I thought it should be. So... nevermind, I'm closing this thread. XD
Question Trying to Understand the Relationship of Amps, Volts, C-Rating...on electrical system DrewC Beginner Training Area (Aircraft-Electric) 41 Oct 10, 2013 04:26 PM
Discussion Relationship between C rating and amps you can charge at? cloud_9 Batteries and Chargers 33 Feb 04, 2013 09:29 PM
Question Brushless Motors: The Relationship between Input Volts & Output Torque poiyt Power Systems 4 Sep 01, 2012 08:29 AM
Discussion Relationship between power supply output and charge rate (?) KRProton Batteries and Chargers 13 Jun 23, 2011 09:28 AM
Discussion relationship between volts and mAH mechmove Batteries and Chargers 26 Apr 09, 2008 05:26 PM
