Old Apr 23, 2015, 06:09 PM
gdimonte is offline
Find More Posts by gdimonte
Canada, ON, Newmarket
Joined Dec 2005
50mm A7 shared data build
I started an A7 build and thought I'd share my data with everyone. So far, I've cut a fuse to mount the edf and do some basic testing. I'm working with Rhino and will provide files for anyone to work with. Feel free to modify the design and post your files for others to work with.
My modeling skills are not the greatest so, forgive some of the gaps.
Inlet (100% fsa) and outlet (85% fsa at end)sized for skyangel 50mm edf.
Elevators are shown in 2 different sizes. One scale, the other larger.
gdimonte is offline Find More Posts by gdimonte
Old Apr 23, 2015, 06:16 PM
gdimonte is offline
Joined Dec 2005
Here are a couple of renders to give you an idea of what I've got so far.
Old Apr 23, 2015, 06:26 PM
gdimonte is offline
Joined Dec 2005
OK, the site won't let me upload the files. e-mail me and I can provide the file in most formats.
3ds
.stp
.igs
.dwg
.dxf
I'll post pictures of the fuse trial build when I get back home on Sunday.
Old Apr 24, 2015, 11:04 AM
mrshea is offline
Find More Posts by mrshea
michigan jet guy
mrshea's Avatar
USA, MI, Caledonia
Joined Jul 2007
thats awesome. always loved the a-7. always wanted to build one but larger. Wiil be following. Phil
mrshea is offline Find More Posts by mrshea
Old Apr 27, 2015, 01:57 PM
Lear45 is online now
Find More Posts by Lear45
Omaha, NE
Joined Jun 2004
Looks good so far. Will the plane be made from solid foam?
A friend and I have made a larger one, but didn't use any 3D modeling.
Jim
Lear45 is online now Find More Posts by Lear45
Old Apr 28, 2015, 09:19 PM
gdimonte is offline
Joined Dec 2005
The plane is cut in sections using a hot wire. This first version is made out of the cheap white foam just to try things out. I don't have any of the internal passages for wires etc. I also need to change the duct shape so that the ESC has a good surface to mate with
Final version to be cut in the stronger blue foam.
Pictures to come.
Old Apr 29, 2015, 07:55 PM
gdimonte is offline
Joined Dec 2005
Here are some pics just to show what it looks like. Rudder and elevators are going to be cut from 6mm depron. I'll cut the wings out of blue foam with an airfoil just so that I can throw it in the air and see how it flies.
There's a cardboard support at the front of the intake. White foam is too weak.
The bottom was hogged out for the ESC. Next version will have the ESC on top. I'm also going to make the intake flat so that the ESC sits properly.
ESC and Battery wires go thru the intake duct. That will be corrected on the next version with the ESC move.
Help! Naza GPS Data Share Adatper Board StevenFox950 FPV Equipment 0 Jan 21, 2015 08:42 PM
Data The "share your telemetry data" thread DrewV Sailplane Talk 19 Nov 16, 2014 10:29 AM
Data DJI NAZA-M Fly Away - REPORTS & DATA SHARING ONLY jaydekay Multirotor Talk 3 Oct 10, 2013 01:34 PM
Build Log DR John's 40/50mm A7 "Pirate II" pmpjohn Micro EDF Jets and Power Systems 110 Jul 19, 2011 01:56 PM
New Product A6 and A7 50mm edf splitpilot Foamy EDFs 3 Apr 11, 2011 10:51 PM
