Old Oct 05, 2014, 07:12 PM
Slopeosapien
jonesymj's Avatar
Joined Jun 2006
Well I put 3 packs thru it this morning... If it quacks, it's probably a...
So not surprisingly it flies just like a Dart, it loops (inside and out), rolls (well kinda, it is R/E) snaps, stall turns and hammerheads, inverted flat spins, t &g's, hovering ... Pretty much anything you'd want a simple silly plane to do, it does. Let my FB Darren beat on it for a while... I'm pretty sure he went home and started one, so I guess he likes it too!
What can I say that hasn't already been said?
Get started building one. You won't regret it!
Ps... Hey Frank! Wasn't that Hamilton out in front? Lol!
jonesymj is online now Find More Posts by jonesymj
Old Dec 20, 2014, 06:26 PM
Joined Oct 2012
When building the Smart Dart does it matterif the tailplane is level with the wing or does it have to be below as in the plan.
Merry Xmas to All.
corflute is offline Find More Posts by corflute
Old Dec 20, 2014, 07:16 PM
flyin' fool
goldguy's Avatar
Vancouver Island, Canada
Joined Jul 2003
As designed it works. Change it and see what happens, nothing in foam is chiseled in stone.
goldguy is online now Find More Posts by goldguy
Old Dec 20, 2014, 11:08 PM
Joined Oct 2012
Thanks for the prompt reply Goldguy.I shall build it as the plan shows.
Old Dec 21, 2014, 01:54 AM
New Zealand, Canterbury, Rolleston
Joined Oct 2011
Because of the vertical taper of the top and bottom of the fuselage, this gives the difference in angle between wing and tail plane ~2 degrees.
Versus the wing I have 6 degrees motor down thrust and 2(?) to the right.
If you give it a reasonably long nose the battery can be fitted under the CoG and it won't matter of you change battery sizes between flights.
Mac50L is offline Find More Posts by Mac50L
Old Dec 21, 2014, 11:37 AM
flyin' fool
goldguy's Avatar
Joined Jul 2003
Right, it's all about the decalage, or the angles of the motor, wing and hor. stabablizer compared to each other. There's a reason for it and it's designed in. Fiddle with it and there's no guarantee you'll have a good flying model.
Still, if you feel the need to change things, build as designed first. Then you'll see the effects of any alterations and know if they are good or bad.
Fiddling is fun, but be prepared for the results.
Old Dec 21, 2014, 02:28 PM
Joined Oct 2011
A modification I've done to help "hard landings" is a short ply panel each side with the firewall across at the front of them. This load-spreads the motor forces. A small horizontal panel on the bottom glued to the side panels is the U/C mounting plate, if you fit one.
Also (why use CF?) run bamboo kebab sticks along the length of the fuselage. You can split them so only half thick but in tension they are strong, light and cheap. I've had the glue the aft end of the fuselage on most of mine theat haven't been reinforced. OK, bad flying.....
Rather than a stick across the wings to stop them folding up I put in a Western Red Cedar wing spar, same thickness as the foam.
The longer nose allows mounting of the servos near the aft end of the wing giving short throws. I cut a slot each side and poke them in from inside and then jam and glue bits of foam between them. Easy to break off the foam to remove them later. No need for screws or wooden mounting plates.
https://sites.google.com/site/kayakamf/rcplanes/dart-xs
Note History and Parts List pages. These are about 22" versions except the blue and yellow one with extended wing span.
Old Dec 22, 2014, 10:22 AM
just Some Useless Geek
Chicagoland
Joined Oct 2008
Eeeeh...I've "fiddled" with the trapezoidal wing plan plenty and come out ahead nearly every time. The wing shape covers a multitude of sins. Having the main wing and horizontal stabilizer parallel isn't so bad; a bunch of my planes came out this way and still fly fine. The Longhorn in particular is my absolute favorite airplane and it's parallel.
Foam is cheap. Knowledge is priceless.
A Useless Geek is offline Find More Posts by A Useless Geek
Old Dec 22, 2014, 10:54 AM
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Seeing Jones-y’s posting from the tenth month ... made me think about all the Dart and Dart variations we made (and there were many ) What we found is , when the standard Dart decalage was preserved , no matter what shape you made it , it still flew like a Dart (which was Wonderful !!!) ... even the radical Round Dart and Martian Dart ... and my all time Favorite (JMHO) being the Tandem Dart which was so really Easy to fly.. All with the exact Dart fuselage proportions for proper wing and tail incidence ... Those that were built with non Dart parameters flew ..."different”...
Light wing loading Darts flew slow and Floaty’ .... Heavier , overpowered Darts were like Rockets ... Both lots of Fun !!! All very predictable ... Reason why the Dart’s been around so long ...
gpw is offline Find More Posts by gpw
Video Smart Dart Biplane Stephan8 Electric Plane Talk 2 Jun 03, 2014 04:35 PM
Discussion SMART DART meets RIPMAX RENO RACER farnboro flyer Sport Planes 3 Aug 06, 2012 10:10 AM
Video Smart Dart XS goldguy Electric Plane Talk 2 Oct 28, 2007 02:57 PM
Video Smart Dart front yard flying dwc Electric Plane Talk 1 Apr 19, 2007 05:16 PM
