Old Oct 19, 2014, 06:22 AM
Australia, VIC, Melbourne
Joined May 2014
Mini-HowTo
FT009 How To... Mods
How To...BY PASS THE SECURITY SYSTEM PROPERLY
Part needed.....
by-passed the security system...why?
to stop possibility of boat going dead in the middle of the lake
and so you can test run it before throwing it in....
(Warning Never Run It For long Out of the water Or held in water, as the motor will cook from lack of water movement under the boat to cool it...)
or you could also Mod the cooling system...see later post
To do this Mod right you will need to replace the water in making the circuit on the boats contacts .... 2 on top or 2 on bottom.....of the security system using a
100meg 1/2watt resistor .... as water seems to be between 100 and 150meg
if you just join up the wires
Your TX.... Controller will start giving you Bad Pairing trouble to your RX... Boat
This Mod can be done very easily buy carefully removing the servo and loosening the
two screws holding the security system wires and just adding the resistor..
between them and putting the servo back, test and your done... have fun
as:- http://i.imgur.com/fzJ2Zym.jpg (sorry pic is a bit fuzzy)
Shaky Shot is offline Find More Posts by Shaky Shot
Last edited by Shaky Shot; Oct 19, 2014 at 08:59 AM. Reason: opened for others to add there Mods
Old Oct 19, 2014, 08:46 AM
Joined May 2014
FT009 Mods including...COOLING UPGRADE up by100 percent
including :- How To...2/ Remove The Stock Motor Coupler Made Easy
(Warning may go flying off.....do over a bench corner may be...)
see my:- How To.... here:- (sorry went out of fame a bit near end)
FT009 Mods including...COOLING UPGRADE up by100 percent (10 min 17 sec)
Cooling Upgrade Mod extra info:-
my tube is 4.1mm od, (can be a bit smaller)...with pickup lining up with top of drive shaft-or higher if you like - you will need to remove soldered case wire and re-run one to front case screw - you will need to block old discharge tube if unused - you should use thermal paste under coils if you have it
(in the video;- I said the angle cut on tube left a 5mm or so hole....it was closer to 8mm+) you can also move pickup up till you find the best spot before you glue it if you want....
http://i.imgur.com/BInMo17.jpg
http://i.imgur.com/cRV8Q5w.jpg
http://i.imgur.com/kap4zjk.jpg
http://i.imgur.com/zTBK6L2.jpg
have fun
Old Oct 19, 2014, 09:20 AM
Joined May 2014
FT009 How To... Mods WANTED working S2 build setups
Looking for cheap fast S2 Brushless build setups
please post any working setups with links or full info of parts only ....am in AU thanks
Discussion How to mod flaps onto the 182 light aircraft Mog2 The Builders Workshop 7 Oct 13, 2014 01:27 AM
Idea Radian mod with Pontoons , HOw TO BigFoot2012 Electric Sailplanes 0 Sep 30, 2014 10:29 PM
Mini-HowTo Blade Nano QX LED mod ( how to guide ) WadzofQuadz Mini Multirotors 6 Sep 27, 2014 03:59 AM
Discussion Ft009 motor mod curlyjoe Micro and Sub-Micro Boats 1 Apr 25, 2014 08:59 PM
Mini-Review fei lun ft009 mods.. daus malaysia Micro and Sub-Micro Boats 2 Mar 24, 2014 10:34 AM
