Old Jan 23, 2014, 04:34 PM
Paul Bonati's Avatar
Buenos Aires, Argentina
Joined Aug 2007
THANKS !!!!! THANKS !!!!! For the help.
As you must know this is my first "scale project", and without all the help you are given to me, probably I couldnīt have arrive at this stage. Wish, someday this "project" could be a final plane, as a gift for all you guys that are sharing your time, efforts and "teaching" with me.
Thanks, Pete G !!! Your information is very valuable, I`m printing it and starting to read.
Yes Shnokey I like your help !!! I must said better...I need your help !! Thanks again for all your help with the cockpit ! I`m not so sure I can get with the printed tissue for the losenge, but I will try, so I will need your losenge. I made a mistake, is not 1/10 sacle, is 1/8 scale. But wait until we all together can define the final camouflage...
Here are some ideas, after searching a lot in the web and reading some books (winsock datafile Fokker D VIII; Guttman J Naval Aces of World War 1 (Part 2)Osprey Aircraft of the Aces No 104; and Fokker Aircraft of World War I)
If I couldnīt manage to do the losenge, I will probably go with the clasic "yellow bee" version.
Cheers, Paul.
Paul Bonati is offline Find More Posts by Paul Bonati
Old Jan 23, 2014, 07:05 PM
a.k.a Maltone
Australia, NSW, Goulburn
Joined Jan 2005
I love it when forum folk go the trouble of helping a modeller in need
Choose a scheme within your capability Paul - or maybe just a little bit harder then you wont be disappointed with it. That's what I do....
Pat
Pat Lynch is online now Find More Posts by Pat Lynch
Latest blog entry: A Small Diversion From Annie
Old Jan 23, 2014, 07:31 PM
AKA Jon Rider
Shnokey's Avatar
United States, MA, Holliston
Joined May 2004
Whatever I can do to help - I can scale any scheme you want and provide the print files, I can actually do the printing of the tissue (or other covering) and send it along or I can provide you with the stencils that you can cut out and paint the Lozenge or yellow yourself - I love to see success like this!!! - Your call - what ever you want to do! -
Shnokey is online now Find More Posts by Shnokey
Old Jan 23, 2014, 07:37 PM
P_J_Glor's Avatar
Valencia, CA
Joined Oct 2002
Cheers, Paul.
Regarding the Goerth Aircraft: The Dragon kit box shows a yellow number 3 and a yellow cowling, but the photograph shows the cowling as much darker than the number. The film used during the World War I time period tended to show yellow as a darker shade, so my thought is that the number was white, since it is so much brighter than the cowling.
If you have any black & white photos of the aircraft with the white and black triangular design on the cowlings, the white portion is probably about the same value as the number on this aircraft and brighter than the cowling in this picture.
As for the lozenge pattern, you may be able to tell by picking out the pattern of the darker colored lozenges that show up pretty well in the photo. If it corresponds to the arrangement of the darker lozenges in the fabric color samples for the four-color lozenge, it is most likely a four color pattern.
One benefit of having so little information on this plane is that once you have committed to your color scheme, it will be extremely difficult for anyone to prove you wrong!
Pete G.
P_J_Glor is offline Find More Posts by P_J_Glor
Old Jan 25, 2014, 10:13 AM
Joined Aug 2007
Getting at the difficult part for me. Fixing the main wing and getting a good aligment. But before that I have more doubts...sorry guys for boring you with so many questions ...
I īve been reading other post and doing the "p clips" I have made from an aluminiun can. I will fixing the land gear with them (using 1 bolt per clip...is that ok?. Can I use only 1 bolt per clip with the wing also? Foir the wing I will be using 2-56 bolts.
Here some photos.
Thanks again, Paul.
Old Jan 25, 2014, 07:17 PM
Norfolk, England
Joined Sep 2001
Paul,
How soft is the aluminium? You might find brass strip. or even strips cut from a tin can more durable. Plus, both of those could be soldered in place to prevent possible movement.
If the aluminium is too soft there's always the risk of a knock bending it at the bolt position. Thereby undoing all your careful setting up.
Pete
PETERRAKE is online now Find More Posts by PETERRAKE
Old Jan 25, 2014, 09:02 PM
Joined Aug 2007
Pete, thanks for your answer. Today, I have a lot of time for fixing the wing. The aluminium is from a "COKE" can. Iīm very happy with the aligment of the wing, but I canīt solder the aluminium to the struts...could I use epoxy for fixing the p clips to the struts?
Paul
Old Jan 25, 2014, 09:06 PM
Pat Daily's Avatar
United States, VA, Chesterfield
Joined Mar 2001
Paul you are doing a great job on your first scale model! I am impressed.
Pat Daily is offline Find More Posts by Pat Daily
Old Jan 26, 2014, 05:15 AM
Joined Aug 2007
Thanks Pat, you are very kind !!!
This project could not be posible without the great help of the forum people that are making a lot of contribution on it.
Paul
Old Jan 26, 2014, 06:10 AM
Joined Aug 2007
A long way done...a long way to do...
Just to see how does it look now.
Old Jan 26, 2014, 06:31 AM
Norfolk, England
Joined Sep 2001
No problems there mate, it all looks just fine.
Yes, no reason why the P-clips can't be epoxied in place on the struts.
Pete
Old Jan 26, 2014, 07:25 AM
Joined Aug 2007
Thanks Pete!
Old Aug 13, 2014, 08:30 AM
tblount70's Avatar
United States, TN, Thompson's Station
Joined May 2004
Paul,
I came across your build thread here when searching DVIII. Enjoyed reading the entire thread.
Your build speed sounds EXACTLY like mine. I take my time (enjoy the building) plus life always slows things down. Unless I'm doing a simple laser cut kit, it usually takes me a year to finish something.
Keep it up! You can do it! Plus I am somehow drawn to the DVIII. I'd love to see what yours will look like when it's done.
Tim
tblount70 is online now Find More Posts by tblount70
Old Aug 13, 2014, 09:36 AM
MikeSawicki's Avatar
Joined Mar 2009
Very nice work!
MikeSawicki is online now Find More Posts by MikeSawicki
Old Aug 15, 2014, 08:38 AM
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Originally Posted by tblount70 View Post
Your build speed sounds EXACTLY like mine.......it usually takes me a year to finish
You and me both!!!
Colonel Blink is online now Find More Posts by Colonel Blink
Build Log Peter Rake's 1/6 Fokker D.VII "Sieben Schwaben" - Now with Video gupi Scale Kit/Scratch Built 248 Oct 22, 2014 07:52 PM
Discussion Peter Rake Fokker D.VII vonJaerschky Scale Kit/Scratch Built 296 Nov 07, 2010 06:11 AM
Cool Peter Rake Fokker D-VIII (IPS version) Steely Dan Scale Kit/Scratch Built 9 Mar 27, 2010 02:05 PM
Fokker D VII by Peter Rake Ian Easton Scale Kit/Scratch Built 158 Dec 21, 2005 11:06 AM
Peter Rake's Fokker D-VIII Jim Drissell Scale Kit/Scratch Built 12 Aug 02, 2002 01:10 PM
