Old Jan 23, 2002, 09:24 AM
blainej is offline
Find More Posts by blainej
Joined Jan 2002
elevon setup
How do I set up elevons in an airplane? I have a Focus 4x and a Hitec 555 RX. The radio has mixing functions. Do I need a Y harness for the aileron servos? Does it matter which channel these servos are plugged into the RX ?(aileron or elev.)
blainej is offline Find More Posts by blainej
Old Jan 23, 2002, 09:56 AM
Jeff Meyers is offline
Find More Posts by Jeff Meyers
Jeff Meyers's Avatar
Fayetteville, GA
Joined Oct 2000
I'm not sure if the 4x has elevon mixing. You can download the manual here:
http://www.hitecrcd.com/ServSup/manuals.htm#how
You won't use a Y harness and it does matter what channel the servos are plugged into.
If you don't have the ability to program elevon mixing with that Tx, you can buy an elevon mixer for under $20.
Regards,
Jeff
Jeff Meyers is offline Find More Posts by Jeff Meyers
Old Jan 23, 2002, 12:32 PM
JasonJ is offline
Find More Posts by JasonJ
Dude, where's My Plane?
JasonJ's Avatar
Green Lane PA USA
Joined Mar 2001
When programing the mix in the TX make sure both values (ele and ali) is set to more than 100% total, like 50 60, or at full input, like full up and right stick the throws will chop each other. any combo is ok if you need it like 60% 40% or 50 /50 as long as it all adds up to 100% or less.
Also use a bit of exp to take the edge off the aircrafts reactions. You still get full throws when you make more extream control inputs. Some radios seem to varry as to weather you use - or + exp, just make sure the surfaces move slowly durring the first 1/2 of the stick input and them move faster to the full throw in the second 1/2 of the stick input.
JasonJ is offline Find More Posts by JasonJ
Discussion Futaba 12Z and elevon setup Myron Radios 2 Jul 21, 2007 05:23 AM
Help! elevon setup - Hitec Flash 5 Rx old man emu Australia 38 Nov 06, 2006 05:34 AM
Elevon setup verk182 Flying Wings 1 Nov 24, 2005 12:32 AM
Zagi 400 elevon setup livinma1 Flying Wings 2 Sep 23, 2005 10:58 AM
Flash 5X elevon setup wattsup_kz Hitec/Multiplex USA 6 Mar 25, 2004 02:17 PM
