Old May 16, 2015, 07:41 AM
YellowJacketsRC is offline
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Yes, I understand about them being just like other lipos. What I am concerned about is whether the radio still operates safely at 7 volts?
YellowJacketsRC is offline Find More Posts by YellowJacketsRC
Old May 16, 2015, 09:06 AM
Fidelity101 is offline
Find More Posts by Fidelity101
Go fast, pull up.
Fidelity101's Avatar
United States, NY, Clarence Center
Joined Nov 2008
The stock battery had a nominal voltage of 7.2v so I don't think 7.0v would be a problem. I downloaded the manual and I can't seem to find anything about the lowest allowable voltage for the transmitter.
However, look at page 69 in the manual...the default cutoff voltage in the Aurora 9x for lipos is 6.0v. They allow you to change that from 6.0 to 6.5 as most lipo manufacturers don't recommend discharging to 3.0v/cell for very long. If the internal settings allow a cutoff of 6.0v then I'd have to imagine the transmitter is still functional at that voltage.
Still, I'd recharged before 7.0v/cell just to be on the safe side...although apparently 6.0v is the default setting.
http://hitecrcd.com/files/Aurora_9X_Manual_EN_V1.2.pdf
Fidelity101 is offline Find More Posts by Fidelity101
Old May 16, 2015, 09:21 AM
Warjet1950 is offline
Find More Posts by Warjet1950
RC Warjet
United States, CA, Jamul
Joined Mar 2013
According to the manual (pg 21), you can adjust battery voltage alarms with the HPP-22.
Warjet1950 is offline Find More Posts by Warjet1950
Old May 16, 2015, 01:59 PM
They Call him Dead!
Joined Jul 2003
Thanks!
Since I don't like going below 3.75, I will use that as the lowest voltage.
Old May 21, 2015, 05:23 PM
Xpress.. is online now
Find More Posts by Xpress..
Hitec RCD CSR
Xpress..'s Avatar
United States, CA, Alpine
Joined Oct 2007
6.0v is the setting for LiPo, wouldn't advise letting it below 6.5 volts. Keep an eye on it and pull the pack out and recharge it when it gets to ~7.5v ish. With a 2600mah 2s lipo, you're going to last quite a long time. One of our team pilots uses a 2s 2600 lipo and he claims it lasts him weeks before recharging and he's always out flying.
Xpress.. is online now Find More Posts by Xpress..
Old May 21, 2015, 05:42 PM
They Call him Dead!
Joined Jul 2003
Thanks!
Old May 27, 2015, 06:49 PM
Little ROG is offline
Find More Posts by Little ROG
Va.Beach Va.
Joined Feb 2007
I finally got some max altitude readings on radio. It held them in the little boxed in portion. My glider was at 396 feet at one point of the flight but I think it stopped. It seemed liked I soared up a little higher after that reading.
Little ROG is offline Find More Posts by Little ROG
Sold Hitec Radio Aurora 9, RXs, HPP-22 jeepx Aircraft - General - Radio Equipment (FS/W) 2 Apr 06, 2013 03:03 PM
Discussion New aurora 9x silva916 Radios 9 Feb 02, 2013 10:29 PM
Discussion Hitec Aurora 9X 3Daddict Radios 5 Feb 02, 2013 02:44 AM
Discussion New Aurora 9X aleXtino Hitec/Multiplex USA 3 Feb 01, 2013 08:13 AM
For Sale DSM2-DSMX transmitter modules for Hitec Aurora 9/Optic 6/ Eclipse 7/Futaba radios hammer22 Aircraft - General - Radio Equipment (FS/W) 0 Jan 08, 2013 09:35 AM
