Old Jan 30, 2013, 10:01 PM
RCLT40 is offline
Find More Posts by RCLT40
RCLT40's Avatar
Joined Mar 2011
Ryan Pt-20
Guys.
I'm working with a high school group that is working to build a full size kit plane. One of there tasks is to finish up a Ryan PT-20 that was donated. But the only information on the plane is listed bellow. I'm hopping someone has a book that would tell me what size servos to use an where the CG is on it. Any info that you can supply would be helpfull
Enjoy your flight with AMD!
| Home | About AMD | Movie Clip | Menu | Products | Forum | Contact Us | Distributor | e-Store |
this is
Specification
RYAN PT-20
Almost Ready-To Fly (ARF)
Lenght
1028mm (40.5")
Wing Span
1630mm (64")
Weight
2.5kg - 2.7kg (88.2-95.2 oz)
Wing Area
41.3dm sq. (444.6 sq in)
Wing Loading
60.5g/dm sq. (29.7 oz/sq ft)
Radio
4 ch.,4 Servo
Engine
4C .52
Kit feature
- Silver Grey color gel-coated FRP fuselage & cowling.
- Gel-coated FRP wheel cover.
- Complete scale mounting wire included.
- Pre-built, pre-covered balsa wing.
- Extremely stable flight performance due to large wing area and light weight.
- Kit includes engine mount, linkage parts and main & tail landing gear.
We've joined the following RC topsites. Click & Rate AMD!
On-line Shops : | AMDhobby | rcMart | TopSpyCam | RC Bearing | Virgo Skin | Manufacturers : | G-Maxx | Yeah Racing |
RC Portals : | rcBaby | Mini-heli | Mini RC | MiniZ turbo | Cybercopter | Others RC : | RC Union |
Aero Model Design (AMD) - Copyright @ 2004-2005
Owned by AMDhobby.com
RCLT40 is offline Find More Posts by RCLT40
Old Jan 31, 2013, 07:48 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
Maybe somebody has a book, but until then:
Standard, non ballbearing servos should be fine. Something in the 42 in oz area.
Balance your model at the thickest part of the airfoil, which is usually the spar.
That is what I would do, if it were mine.
TomCrump is offline Find More Posts by TomCrump
Old Jan 31, 2013, 09:19 PM
RCLT40 is offline
RCLT40's Avatar
Joined Mar 2011
Thanks. Going to start on it this coming Monday so will see what it looks like then
Old Feb 01, 2013, 02:17 PM
Chad Veich is offline
Find More Posts by Chad Veich
Scale Builder
United States, AZ, Litchfield Park
Joined Jul 2002
Standard practice on a model with a constant chord wing is to balance at 1/3 of the wing chord. This will most likely be very close to the thickest point of the airfoil as noted by Tom. When in doubt err on the side of caution and balance more forward. Starting closer to 1/4 of the chord, while definitely more forward than necessary, should not result in any drastically negative effects. My .02 cents anyway.
Chad Veich is offline Find More Posts by Chad Veich
Old Feb 04, 2013, 02:52 PM
RCLT40 is offline
RCLT40's Avatar
Joined Mar 2011
So after looking at the plane again we decided to go electric. The box says it needs a 4c 52 engine what size electric would I need? Id like to possibility get it from hobby king because the school is on a budget.
Wanted Randolph Hobby Products Ryan PT-20 Mike Denest Aircraft - Fuel - Airplanes (FS/W) 0 Dec 24, 2005 12:24 PM
Wanted Randolph Hobby Products Ryan PT-20 Mike Denest Aircraft - General - Miscellaneous (FS/W) 0 Dec 24, 2005 12:23 PM
FS Mark PT 20 Ryan kit Vintage McLeodAviation Aircraft - Fuel - Airplanes (FS/W) 0 Jul 07, 2004 01:46 PM
Tom Hunt's Ryan PT-20 Neil Morse Scale Kit/Scratch Built 3 Jul 17, 2003 10:23 AM
Article The HSS Ryan PT-20 Pat Mattes Electric Plane Talk 0 Jun 01, 1999 12:00 AM
