Old Sep 11, 2013, 10:50 AM
Steve Merrill is offline
Find More Posts by Steve Merrill
Steve Merrill's Avatar
USA, IL, St Charles
Joined Nov 2002
Originally Posted by sloperjoe View Post
2 5/8" inches back from where the wing leading edge meets the wing strake section, should get you in the air, you can adjust your batts to suit how you like it from there
Joe
Thanks Joe. Lookin like this Saturday/Sunday for my maiden.
Steve Merrill is offline Find More Posts by Steve Merrill
Old Sep 11, 2013, 11:04 AM
i12flyrc is offline
Find More Posts by i12flyrc
i12flyrc's Avatar
Columbus, Ohio, United States
Joined Jul 2003
Good Luck! Post pics and/or video.
i12flyrc is offline Find More Posts by i12flyrc
Old Sep 11, 2013, 02:21 PM
sloperjoe is offline
Find More Posts by sloperjoe
sloperjoe's Avatar
United States, WA, Vancouver
Joined Mar 2012
most welcome, and I second the video request
Joe
sloperjoe is offline Find More Posts by sloperjoe
Old Sep 11, 2013, 04:08 PM
USA, IL, St Charles
Joined Nov 2002
Will do, and I Fly: Nice video! I grew up as a Buckeye fan. Dad and my Grandfather went to OSU.
Old Sep 14, 2013, 11:39 AM
USA, IL, St Charles
Joined Nov 2002
Here is the maiden video. Short and not so sweet. I think I have a stab to wing alignment issue that I need to fix. Also, notice how she turns to the right. It seems I need more thrust. I used a brand new 3-cell 890mah Lipo. AUW is 13 oz. Watt meter said I was just under 100 watts. Something is not right. Maybe when I fix the tail issue, and I try again, when she gets up on step things will go better...
A6 intruder maiden (0 min 18 sec)
Old Sep 14, 2013, 01:55 PM
sloperjoe's Avatar
Joined Mar 2012
hhmmmm....
definitely didnt sound right...I could launch mine at half throttle and climb out no problem...some people reported that the alloy fan units they got had issues, the two I bought were great
Joe
Old Sep 14, 2013, 02:49 PM
USA, IL, St Charles
Joined Nov 2002
I know it doesn't sound like its developing full power. I will play around with the ESC and try to squeeze out more RPM. It will be hard to replace the fan unit without destroying the plane. I also think it should be ok if I fix the tail alignment
Old Sep 14, 2013, 07:05 PM
i12flyrc is offline
i12flyrc's Avatar
Joined Jul 2003
Steve,
Keep trying. Looks like you almost have it. The initial flight off the hand launch looked like it was going to just fine. It did sound a little under power but still like it had more than enough to fly. In addition to double checking the CG, check the lateral balance.
You may have an alignment issue like you said but if there is any lateral ( left to right) balancing that needs done, that might lessen the amount of alignment you may have to do.
Old Sep 15, 2013, 11:13 AM
USA, IL, St Charles
Joined Nov 2002
Good point. If anything, the left wing tip is slightly heavier. I fixed her up this am. Also, one of the taileron servos stopped working, as the crash pop the servo extension lead, so I had to do some surgery to get to it, and add some tape, so it doesn't happen again.
I was thinking about removing the piece of foam that goes into the tail pipe, that forms the fuse rear bottom. Do you guys think this is really needed? My thought is that this would open up the tail pipe, and allow more air to exit, and hopefully more thrust.
Thoughts?
Old Sep 15, 2013, 12:27 PM
sloperjoe's Avatar
Joined Mar 2012
Thoughts?
that part stiffens the tail section, without it the tail may snap off in a turn, it really doesn't interfere with the thrust enough to worry about.
what is the C rating on your pack, if it is low it could be your problem, a 15-20 C rated pack isnt going to supply enough amps to that fan unit, I've been using Turnigy Nano Tech 3s 1000mah 45-90 C packs
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Joe
Old Sep 15, 2013, 12:49 PM
USA, IL, St Charles
Joined Nov 2002
Ok I'll try that Joe. The battery I am using is 25c
Old Sep 15, 2013, 04:15 PM
i12flyrc is offline
i12flyrc's Avatar
Joined Jul 2003
Steve,
If you opt to remove the piece behind the thrust tube on the underside of the fuse and tail, you could laminate a small flat carbon strip along the bottom for added strength with little weight. Was thinking maybe a 1mm x 3mm x the length of the splitter.This would stiffen that area up and allow better air flow if needed. I have done this on the insides of fuselages for added strength. Just a thought.
Old Sep 16, 2013, 11:49 AM
USA, IL, St Charles
Joined Nov 2002
Thanks guys. I bought a new 45C lipo today from HK. We'll try that and see if I can get some more thrust. What connectors are you guys using? The motor only pulls about 9 amps now, so I am using those little JST connectors. If I pull more than 10amps, I may have to use Sermos connectors. They are big and bulky, and heavy.
Old Sep 16, 2013, 12:09 PM
sloperjoe's Avatar
Joined Mar 2012
9 amps!!!!!!!!!!!!!.......... full throttle should be twice that. either you got a bum unit, have too small gauge wiring, a bad ESC, weak solder joint....or something....9 amps is definitely under powered.
I use Deans "t" connectors on 50mm fans on up, they hold up nicely.
Joe
Old Sep 16, 2013, 01:53 PM
USA, IL, St Charles
Joined Nov 2002
Hmmm. Well, let's see what the new battery gives me. I will go do a test before getting the new battery, I have other 3-cell lipo's, with higher C rating, will hook up to the watt meter and see what I get. Please stand by...
Discussion A-6 Intruder Profile, Kf-2 PLANS sugas182 Foamies (Scratchbuilt) 9 Jul 19, 2012 03:31 PM
Wanted A-6 Intruder Orion Pax Aircraft - Electric - Jets (FS/W) 2 Apr 30, 2012 07:26 PM
For Sale A-6 Intruder EDF Angelo Aircraft - Electric - Airplanes (FS/W) 2 Mar 21, 2012 08:10 PM
For Sale A-6 Intruder Angelo Aircraft - Electric - Jets (FS/W) 0 Mar 21, 2012 06:15 PM
For Sale Kyosho A-6 Intruder, Chicago area Angelo Aircraft - Electric - Airplanes (FS/W) 2 Feb 26, 2012 11:04 AM
