Old May 02, 2015, 03:54 PM
Extraboy is offline
Find More Posts by Extraboy
To Live is to Fly
Extraboy's Avatar
Australia, VIC, Melbourne
Joined Aug 2011
Sounds like the rx is not bound properly. Try re-binding and see if that works. If not, before you connect your battery to the rx push your throttle stick to full on your tx , connect battery, wait for double beeps then bring your throttle stick back down. This will reset your esc.
good luck
Extraboy is offline Find More Posts by Extraboy
Old May 02, 2015, 07:47 PM
peterswolf is online now
Find More Posts by peterswolf
peterswolf's Avatar
United States, FL, Ruskin
Joined Apr 2012
good luck
Extraboy's advice works most of the time for me. A lot of new planes I've been getting lately I've had to do that full throttle to initialize the throttle range first. A couple of my FMS planes it turned out I needed to reverse the throttle channel to get it to work.
But certainly a word of advice, make sure to the this with the PROPS OFF Much safer that way, just in case...
peterswolf is online now Find More Posts by peterswolf
Old May 02, 2015, 08:15 PM
Cubcrazy is offline
Find More Posts by Cubcrazy
Scale Foam Flyer
Cubcrazy's Avatar
United States, AR, Cabot
Joined Oct 2007
Throttle calibration of the ESC should be performed on every single plane you ever buy. Taking the prop off is definitely a must. I once got 26 stitches in my leg for not obeying that rule.
-CC
Cubcrazy is offline Find More Posts by Cubcrazy
Latest blog entry: Carbon Z Cub Floats are here!!
Old May 02, 2015, 08:35 PM
ElectFoam is offline
Find More Posts by ElectFoam
Joined Jan 2013
Originally Posted by jetmann View Post
I have not been able to get my motors started yet. When I plug my rx in, all i get is constant beeps. Any ideas?
That is usually and indication of throttle not being all the way in the down position or a lose motor wire / bad connection.
ElectFoam is offline Find More Posts by ElectFoam
Old May 03, 2015, 06:38 PM
jetmann is offline
Find More Posts by jetmann
jetmann's Avatar
Japan, Kanagawa Prefecture, Atsugi
Joined Feb 2013
good luck
Thanks will try that.
jetmann is offline Find More Posts by jetmann
Old May 08, 2015, 09:16 PM
Dan mach is online now
Find More Posts by Dan mach
Failure is not an option
Dan mach's Avatar
United States, GA, Augusta
Joined Dec 2012
I just received my batteries. Two turnigy lipoly 5s 3300 mah 30c. Both fit under the cockpit without any trimming. This should give the stock motors and props plenty of power and a decent flight time also. I am using a 6v nimh battery to power the electrics.
Dan mach is online now Find More Posts by Dan mach
Old May 14, 2015, 09:19 PM
angelo1939 is offline
Find More Posts by angelo1939
Joined Nov 2012
spare parts...as off may 2015
Banana Hobbies NOW has a lot of spare parts...but unfortunaly NO Giant B25, all are on back-order...Troy Bilt Models makes a larger B25, 2,400 mm, fiberglass fuse, wooden wings and stabs.. airframe only.NO electronics or retracts or motors, $699.00...you have to pay for shipping...
angelo1939 is offline Find More Posts by angelo1939
Old May 19, 2015, 08:03 PM
Dan mach's Avatar
Joined Dec 2012
Two turnigy lipoly 3300 mah 5s 30c batteries fit under the cockpit perfectly.
6600 mah total will give good flight times. Will post my times when finished.
Old May 20, 2015, 02:01 AM
Extraboy is offline
To Live is to Fly
Extraboy's Avatar
Joined Aug 2011
I like the idea of the 2 x 3300's. Just never thought they could fit nicely. Well done.
Love to see a pic of fitment and interested in flight times too.
Old May 20, 2015, 05:46 AM
AussieHoppy is offline
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
Or buy the LX 2000mm B25 from f-hobby
AussieHoppy is offline Find More Posts by AussieHoppy
Build Log New LX FA-18 twin 70mm EDF {from LX models & Blitz works R/C} brandonmoon Foamy EDFs 1444 Apr 05, 2012 01:38 AM
Video LX B-2 Landing Gear RGS2010 Electric Plane Talk 3 Oct 03, 2011 07:16 AM
Wanted JR models B-25 parts wingman11570 Aircraft - Electric - Airplanes (FS/W) 0 Aug 04, 2011 01:14 AM
Wanted JR Models B-25 jricchio Aircraft - Electric - Airplanes (FS/W) 0 Jul 16, 2011 01:36 PM
Sold JR Models B-25 onio condor Aircraft - Electric - Airplanes (FS/W) 2 Jun 25, 2011 08:12 AM
