Hi
You can do it by building a simple mechanical servo mixer.... post 9 here http://www.rcuniverse.com/forum/m_20...tm.htm#2021715 is the best example I could find after a very quick google.... The flaps servo in the above example will open and close the kitchen rudder (suppose on the throttle channel) and the aileron servo will operate the rudder for steering.. I was thinking of doing this myself but after thinking about it was worried the closing of the rudder may stall the tiny midwest power plant... |
The link provided in nick_75au's blog explain well this control system:
http://www.rcgroups.com/forums/showp...59&postcount=1 And that can be achieved very easily with a V-tail mixer and two servos, or done with a Tx which has that mix. Here is an example of V-tail mixer to use between the Rx and two servos: http://www.bphobbies.com/view.asp?id...=T498579&img=l If its for a very small steam boat(midwest steam engine) a 2.4 Ghz radio would be best as they use a very short antenna, something like this would be adequate(and has V-tail mixer build in the Tx) http://www.hobbyking.com/hobbyking/s...x_Mode_2_.html |
| Thread Tools | |
| Sold MKS BLS980 Rudder Heli servo Titanium Gears | edge_pilot | Aircraft - General - Radio Equipment (FS/W) | 0 | Apr 11, 2013 04:38 PM |
| Discussion Elevator servo torque vs rudder servo torque | wollins | Modeling Science | 9 | Jan 11, 2013 04:00 AM |
| Idea Midwest fantail launch + Kitchen rudder | peconic steam | Scale Boats | 91 | Oct 28, 2010 09:59 PM |
| Discussion Kitchen Rudder | steamboatmodel | Scale Boats | 12 | Oct 11, 2008 10:21 AM |
