Old Jan 31, 2013, 06:13 AM
Joined Nov 2012
Feiyutech FY-31AP live telemetry download via A/V transmitter
Hi, has anyone tried successfully to download the telemetry data from the Feiyutech FY-31AP via the audio channel of an A/V transmitter and display the live aircraft location and telemetry info on the 2D GCS 4.0 or GCS 3D software?
Connections
FPV air platform:
FY-31AP UART TX pin connected to Audio-L or Audio-R channel of the A/V transmitter.
FPV ground platform:
Audio-L or Audio-R channel of the A/V receiver connected to the TTL / USB interface linked to a laptop with GCS software installed and relevant COM port open.
thanks
skylimit is offline Find More Posts by skylimit
Old Feb 01, 2013, 01:09 PM
Better then Sliced Bread!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Connections
FPV air platform:
thanks
It would require a piece of hardware to modulate the data to sound and demodulate it back to data, could be done, I am not so sure if any existing systems could do it without code modifications though.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Latest blog entry: Flying in the Neighborhood
Old Feb 01, 2013, 04:17 PM
Joined Nov 2012
Thanks for your reply. I've tried to simply connect the signal cable between the FY-31AP and the Hornet OSD to the audio channel of the Vtx and some of the telemetry can be downloaded live on the GCS 3D software by just connecting the audio output of the AV receiver to the TTL interface provided with the FY-31AP. The artificial horizon and the compass status are updated but the remaining telemetry data is not correctly downloaded (e.g. GPS coordinates, battery, temp, altitude etc). I was wondering if anyone managed to download the full telemetry data without using additional hardware.
Old Apr 01, 2013, 03:54 PM
Joined Apr 2013
FY Downlink Wiring and Connection
Hi Skylimit,
I am a new User in this Forum. My Name is Thomas.
I think, it is a great Idea to recieve the live Data about the Audio Plug to the Computer. Itīs only a Downlink (only recieve Data to Computer).
Which Transmitter and Reciever do you use?
Is there a small Microphone on the Transmitter Circuit Board?
If there is a Microphone on the Board, it can cause many Troubles in Context with the Audio Channel.
It should be possible to change the Video and Audio Plug.
Maybe you can select the Audio Plug, to download the Video Signal.
And then, you can use the Video Plug to download the Live Data about a clear Signal.
But itīs only a Idea!
Today, i bought a FY 31AP with Hornet OSD, too.
In a few Days it should be arrived. Then itīs Time to attempt this Idea.
I am using a 5.8 Ghz 200 mW transmitter and a RC305 Reciever on my Aicon A5 Plane.
Thomas
Subidriver is offline Find More Posts by Subidriver
Old Apr 02, 2013, 05:18 AM
Joined Nov 2012
Originally Posted by Subidriver View Post
Hi Skylimit,
Thomas
Hi Thomas,
my audio/video transmitters have no microphone embedded in their circuit board, they just transmit the audio signal they receive from the camera or any other source connected to one of their audio channel inputs. I'll try to swap audio and video channels to see if it makes any difference.
It would be great to have an update on your testing results once you'll have received your equipment.
FYI, the downlink of telemetry via the audio channels works very well when using the Immersion RC EzOSD telemetry module connected to the audio channel of the audio/video transmitter; I can download live telemetry to iPhone/PC via the audio input or just record it on the audio track of my video recording to play it back later.
Old Apr 03, 2013, 03:40 AM
Joined Apr 2013
Hi,
are there more Audi Channel Inputs on your Transmitter/Reciever or is there only one Plug (Stereo or mono).
If there are two Plugs for Audio, the Transmitter and Reciever would split the Signal.
Course a Idea.
I have seen any Threads about recieve Telemetry Data from a Plane about Audio Signal.
Actually, there is a Way about a small Voice Modem.
I have lost the Link, must see....
Old Apr 03, 2013, 05:27 AM
Joined Nov 2012
Hi,
Course a Idea.
Hi, in order to clarify, all the video transmitters and the receivers that I'm using have separate video, audio-left and audio-right connections.
The transmitter/receiver set-up works perfectly with other telemetry hardware (e.g. the EzOSD), there's no mix of signals between audio-left (audio from the camera) and audio-right (telemetry data).
I'm trying to make it work with the FY 31AP/Hornet set-up; I can hear from the audio recordings that the telemetry data is sent via the correct audio channel.
At this stage I would consider the issue linked to one of these factors:
- the telemetry signal is not transmitted correctly (e.g. not enough bandwidth on the audio channel, interferences, other requirements I am not aware of etc.)
- the signal is not de-modulated correctly when received
The connection is definitely working, as I can receive partial live telemetry information (e.g. plane’s attitude), so I would exclude discussions on sending/receiving the signal on the correct channel.
Old Apr 03, 2013, 02:10 PM
Joined Apr 2013
OK,
the Audio Connection works fine.
I think, we need a Modem to handle the UART from Hornet about a Audio Connection. Like a Voice Modem on Computers.
Take this:
http://www.rcgroups.com/forums/showthread.php?t=1556714
Old Apr 08, 2013, 02:33 PM
Joined Apr 2013
What do you think about it?
Tom
Question Is fy-31ap and the Hornet OSD compatible with fy-90qpro? mgs0098 Video Piloting (FPV/RPV) 0 Jan 16, 2013 10:00 AM
Question Is fy-31ap and the Hornet OSD compatible with fy-90qpro? mgs0098 Power Systems 1 Jan 11, 2013 03:47 PM
Sold FeiyuTech FY-91Q w/ GPS HeliFlightCenter Aircraft - Electric - Multirotor (FS/W) 4 Jan 05, 2013 12:08 PM
Question fy-31ap/ap117 julie32 Video Piloting (FPV/RPV) 0 Jan 03, 2013 04:25 AM
Idea FY-21AP/FY-31AP and OSD FY Extender hefest Video Piloting (FPV/RPV) 6 Nov 05, 2012 04:45 PM
