Old Mar 20, 2015, 01:52 AM
Spotty Herbert
United Kingdom
Joined Oct 2012
Good to see you back in this thread Junsi. Your support is appreciated
DucknDive is offline Find More Posts by DucknDive
Old Mar 20, 2015, 10:27 AM
Germany, BY, BA
Joined Sep 2014
Originally Posted by Pozzix View Post
... I have a 206B charger I'd like to add an external resistor for better (quickly) discharge my batteries...
There is a particular type that I can found somewhere?
Thank u so much for any help....
Max
No there is no allround resistor for this purpose. You have to built up your own specific resistor for your type of battery (if it is a 3s, 4s or 6s) and for the desiered strength of discharge current.
When the blinding of halogen light bulbs is no problem for you, it would be the cheapest way to use 12V or 24V 6.35 pin based lamps for a external discharge resistor.
If you will use resistors, then the „truglodites iCharger Expanded Discharge tool--Spreadsheet“
http://www.rcgroups.com/forums/showa...1&d=1320227505
would be a good help.
When you can specify your type of battery and the aimed discharge current, I can give you some further advice.
RNFLY is offline Find More Posts by RNFLY
Old Mar 20, 2015, 11:11 AM
Cheese5's Avatar
United States, CA
Joined Jul 2010
Originally Posted by junsi View Post
Hello Sir,
Please see the instructon of the calibration file:
“Vo” calibration
Use these 2 points of calibration method, to ensure voltage can be well calibrated:
 Connecting nS batteries,and calibrate ”Vo” first。
(3010B,1010B(+): n=10 306B,206B,106(+):n=6 208B:n=8)
 Then connection 3S(11-13V) batteries,and calibrate ”Vo”.
You can connect 6S first, then 3S to calibrate, and repeat several times to reach the correct value, if it still fail, we are sorry your charger need repairing. I'll try your method above before I pack and send my charger back.
Junsi
Thanks for the reply, I've contacted progressive customer service and they told me to send it back for RMA out of warranty repair. Hopefully they can fix the problem.
Cheese5 is online now Find More Posts by Cheese5
Old Mar 20, 2015, 12:01 PM
Joined Aug 2010
http://www.myrcmart.com/rcx-3in1-bat...ng-p-4767.html
thekubiaks is offline Find More Posts by thekubiaks
Old Mar 20, 2015, 02:20 PM
Son, Norway
Joined Sep 2004
Regenerative discharge.
Btw, I thought bulbs were useless as external discharge resistor because of the aggressive change in resistance?
Fred
flarssen is offline Find More Posts by flarssen
Old Mar 20, 2015, 02:28 PM
aka: Scott Ellis
Xeric's Avatar
United States, MT, Billings
Joined Dec 2012
Fred
That is, apparently, a problem. I'm wiring up a bulb discharge thingamabob right now, but it'll only be used with the charger in the Monitor mode.
Xeric is offline Find More Posts by Xeric
Old Mar 20, 2015, 02:34 PM
Germany, BY, BA
Joined Sep 2014
Could be a problem, when you will go to the max. limit. Then the solution is to divide the load and start up with the half load.
Old Mar 21, 2015, 10:04 AM
United States, MA
Joined Jan 2011
I built my resistor-based discharge load intending to use it with Expanded Discharge (Discharge+). But that didn't really work out for me. The current ended up being higher than the allowable range for my 106B+.
I ended up simply using Monitor mode, which worked nicely, and lets me discharge at however many amps I want (~12A on 6S, for ~300W). I just have to disconnect the load manually when the Monitor alarm goes off.
RedOctobyr is offline Find More Posts by RedOctobyr
Old Mar 21, 2015, 12:28 PM
What goes up must come down
Bush Pusher's Avatar
United States, NH, Rochester
Joined May 2014
Could anyone tell me if my thinking is right on this icharger 106B+ display
0.08 = 80 milliamps
0.80 = 800 milliamps
8.00 = 8 amps
and so on and so forth, just making sure not to over charge anything.
I charge my 3.7 volt 150mah lipo battery at 0.10 which should be 100 milliamps ?
Thank You
Bush Pusher is online now Find More Posts by Bush Pusher
Old Mar 21, 2015, 12:56 PM
Germany, BY, BA
Joined Sep 2014
Yes, your numbers are absolutely right.
Old Mar 21, 2015, 12:57 PM
Joined May 2014
Thank you very much
Old Today, 05:15 AM
Still flying
Ramnes's Avatar
Oslo, Norway
Joined Feb 2009
measuring IR ?
Hi
I have a 106B and was told that my nano-tech batteries IR should be around 2 for all cells, and they all are, but when measuring IR on a quite new Life 3S Tx battery it says 44-40-30.
Does anyone know what i can expect to measure for the different type of batteries like Lipo, Nano-Tech Lipo, Life, and 18650 batteries. What values are good and what values are not good? I've tried to read about it, but i'm not very good at this electro stuff, so please bear over me with a table
I measure the batteries right after charge is finished in room temperature.
Jorn
Ramnes is offline Find More Posts by Ramnes
Old Today, 06:43 AM
Son, Norway
Joined Sep 2004
IR also depends on cell capacity.
Tx batteries usually have low C-rating so relatively high IR is normal, but the variation you got seems a bit big.
Fred
Old Today, 07:48 AM
Still flying
Ramnes's Avatar
Oslo, Norway
Joined Feb 2009
Fred
Hei Fred
I saw a list a few years ago that gave me an idea of what was an acceptable range for the different batteries, but now I can't find it.
My batts:
TGY nano-tech 3S 5000mah flight batts
TGY 3S LiFe 1500mah
No Name 3S 800mah
No Name 3S 1500mah
Jorn
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
