Old Feb 16, 2015, 08:40 AM
Erik with a K
tvcasualty's Avatar
Toledo, OH
Joined Aug 2007
SketchUp: NCGen - Automatic Airfoils
I've been doing some coding I've been meaning to get to for a long time now to automatically generate airfoils with Sketchup. There have been simple dat file loaders people have designed in the past that work well for dropping in a single non-scaled airfoil, but there was a lot missing to complete a wing.
This extension now allows for some specific parameters to be used to define a wing with a single "draw" button.
This allows:
  • One click user parameter defined wings directly into Sketchup.
  • Two more clicks to transform the wing into a 4 axis CNC wire tool path.
    OR
  • Easily skinned shapes (with other extensions like Fredo's Curviloft) to complete a wing model.
Sketchup NCGen: Automatic Airfoils (3 min 4 sec)
tvcasualty is offline Find More Posts by tvcasualty
Old Feb 19, 2015, 08:35 PM
I make bad look so good.
SteveC68's Avatar
League City, Texas
Joined Sep 2006
Outstanding!
For the non NACA airfoils can you specify different root and tip airfoils?
SteveC68 is offline Find More Posts by SteveC68
Old Feb 22, 2015, 06:37 PM
Erik with a K
tvcasualty's Avatar
Toledo, OH
Joined Aug 2007
Originally Posted by SteveC68 View Post
Outstanding!
Yes you can!
...but only 4 digit as of right now.
I'm working on the ability to load different root and tip foils as well, but if the data count is different, the solution becomes more difficult... we will get there eventually.
Old Feb 23, 2015, 08:19 AM
The Junk Man
Jacksonville, Florida
Joined Jul 2006
Is the problem different numbers of segments in the different airfoil plots? Would something like a weld tool followed by division of the resulting "line" work?
Tom
T_om is offline Find More Posts by T_om
Old Feb 23, 2015, 06:55 PM
Erik with a K
tvcasualty's Avatar
Toledo, OH
Joined Aug 2007
Yes the problem is the number of points, and to directly to your question, the answer is no, but, yes there are work around using other extensions...
I should say that the issues isn't so much as drawing them, they can have any number of segments. It's when the next step is taken and hot wire tool paths are created they must be equal...
Short term, I will have a warning to advise the user of the situation.
Long term, the wire path tool just needs to get smarter.
Old Feb 25, 2015, 06:55 PM
Jim C Patrick
jcpatrick's Avatar
Shenandoah County
For years I have used Martin Hepperle's program ConCord to convert all kinds of airfoil data to DXF for import into SketchUp and other CAD. It has the ability to normalize the number of segments —a user specified number— so you can mix NACA foils with other foils.
jcpatrick is offline Find More Posts by jcpatrick
Old Feb 25, 2015, 08:12 PM
The Junk Man
Joined Jul 2006
THANK YOU for that link. I have been having a problem with the airfoil.dat importer plugin in Sketchup with some airfoils. Not all, but some. Running them through that "smoother" fixed the problem.
Tom
Build Log xflr5 / Blender / Sketchup / CNC Slope Foamie Project chrisd438 CAD/CAM 12 Dec 09, 2014 08:25 PM
Discussion Sketchup Model of a Cobra 4130 Outrunner aymodeler CAD/CAM 2 Dec 07, 2014 10:19 AM
Discussion Automatic Canting Keel Project Concordia Uni Sailboats 31 Nov 21, 2013 09:26 PM
Sold Water Buoy automatic flotation device. Johnnymeg Non R/C Items (FS/W) 7 Oct 08, 2013 10:32 PM
