Old Jan 05, 2015, 02:02 PM
gordinir8's Avatar
Athens Greece
2 to 3 blade prop conversion chart
I was wondering if there is a chart that converts a 2 blade prop size to 3 blade prop.
I would like to change my APC 11X7 prop to a three blade.
gordinir8 is online now Find More Posts by gordinir8
Old Jan 05, 2015, 02:49 PM
I TOBOR's Avatar
Joined Feb 2007
www.zingerpropeller.com
Follow the Products button.
This might be better, http://www.zingerpropeller.com/_2_blade_.htm
I TOBOR is offline Find More Posts by I TOBOR
Old Jan 05, 2015, 02:56 PM
gordinir8's Avatar
Athens Greece
makes a little difference, drops only an inch diameter and keeps the same pitch as a general rule.
Thank you
Old Jan 07, 2015, 02:10 PM
United States, FL, Miami
Joined Mar 2012
Thank you
Exaclty!! that is just a simple "general rule"... your particular plane and the way how you like to fly will give you the final words.
Here you will find a lot of debates on how efficient are the 3 blade props versus the 2 blades, some with NASA-geek data and other of people just liking the way how a 3 blade looks... anyway, IMHO every plane/pilot has its own characteristics hence my advise.
cheers
larryoakley is online now Find More Posts by larryoakley
Old Jan 07, 2015, 06:44 PM
Max Tenet
Joined Oct 2005
The real I found problem is getting a spinner to fit them. They do look nice though.
Max
Max Tenet is online now Find More Posts by Max Tenet
Old Jan 07, 2015, 07:11 PM
Joined Mar 2012
Max
I got all my 3 blade spinners from Hobbyking, good quality and waaaay better price.
Sold Dynam 9 x 6 x 3 - 3 Bladed Prop x 2 Mikemynameis Aircraft - General - Miscellaneous (FS/W) 0 Oct 16, 2014 09:34 PM
For Sale Prop charts to help you select the right Prop & Threads $2.49 unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 13, 2014 06:04 PM
For Sale Prop charts to help you select the right Prop & Threads $2.49 unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 06, 2014 06:57 PM
For Sale Prop charts to help you select the right Prop & Threads $2.49 unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 0 Apr 18, 2014 07:04 PM
For Sale Prop charts to help you select the right Prop & Threads $2.49 unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 0 Feb 22, 2014 01:00 PM
