Old Apr 30, 2011, 01:51 AM
Chocks's Avatar
United States, CA, Vacaville
Joined May 2008
Gluing Depron?
I know this question is going to stir a lot of opinions. what is the best glue for gluing Depron. I have read everything from Elmers to Epoxy. I have some white glue that I bought at Micheals that is for foam. I haven't tried it on Depron yet. What is Welders glue and where do you get it from? Any suggestions will be greatly appreciated. Thanks,
Chocks is offline Find More Posts by Chocks
Old Apr 30, 2011, 02:18 AM
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
I have found odorless (foam safe) CA to work ok. At least on the depron that I used. There may be differences between manufacturers.
Do NOT use CA de-bonder...ask me how i know.
KE Spin is offline Find More Posts by KE Spin
Old Apr 30, 2011, 08:33 AM
It's Just Foam!!!
EZglider's Avatar
Canton,Ga
Joined Apr 2010
Foam safe ca works (but becomes brittle) White Gorilla Glue is good with practice (easy to use too much). DO NOT use Welder's on Depron. It will melt the foam!
EZglider is offline Find More Posts by EZglider
Old Apr 30, 2011, 08:53 AM
United States, OH, Northwest
Joined Jan 2011
I really like using using the "Gorilla Glue Precision Glue Pen" which is actully a small tube of clear Gorilla Glue that is an expanding glue that dries turning to a white foam. Walmart carries it. For small cracks in my little UMX Extra 300, I keep a cup with water and a q-tip on my work bench to dampen the crack, then I use a toothpick to dab a tiny amount of the glue in the crack. I then clamp/weight the part flat and after a couple minutes I wipe off the bulge of glue expanding from the crack. I have not really timed the cure time, but after an hour I have flown the plane again with no issues.
I really like the stuff because it fills voids on it's own and when dry it seems to be nearly identical to the foam. Subsequent crashes rarely result in a break in the repaired areas.
If one forgets to wipe the part off after the glue has expanded at the crack line, you can use a dremel tool with a small round abrasive wheel to lightly "grind" off the excess.
Hancock is offline Find More Posts by Hancock
Old Apr 30, 2011, 10:11 AM
United States, CA, Temecula
Joined May 2006
Try Foam-Tac by beacon, dries clear, holds strong and is flexable. Some Micheals carry it but if not you can order from RCFoam.com $3.95. It works on all foams.
2006rfarmer is offline Find More Posts by 2006rfarmer
Old Apr 30, 2011, 10:56 AM
San Diego, CA
Joined Oct 2001
Depron Glue Chart
A while back we put together this glue chart. This shows the different applications and issues with a large variety of glues available on the market.
DW Glue Chart
www.DWFoamies.com
electric-2000 is offline Find More Posts by electric-2000
Site Sponsor
Old Apr 30, 2011, 04:54 PM
Chocks's Avatar
Joined May 2008
Thank you everyone that replied to my gluing question. It is very valued information. And thanks especailly to Mike. I can't wait to get my plane next week. Loran
Old May 03, 2011, 01:18 PM
D/FW
Joined Aug 2004
I like UHU Creativ for depron. It's flexible, strong, and dries fairly quickly. It's hard to find though.
JoeDirtRC is offline Find More Posts by JoeDirtRC
Old May 03, 2011, 02:51 PM
Switzerland
Joined Feb 2004
Beli-Zell is the best.
zibobman is offline Find More Posts by zibobman
Old Nov 24, 2014, 08:30 PM
Denisesewa's Avatar
United States, CO, Caņon City
Joined Sep 2002
Readily available, cheap, Depron safe, good bond ...
The Depron glue question gets asked often. Here's a link to a, IMO, good choice (post 264, page 18):
http://www.rcgroups.com/forums/showt...235953&page=18
Denisesewa is online now Find More Posts by Denisesewa
Old Nov 25, 2014, 11:19 AM
Joined Jul 2014
Foam-Tac is good for most foams. Dedpron to Depron is does real well. the white Gorilla glue is great on Depron, especially for stuff like gluing carbon fiber into pockets and filling gaps etc.
The nice thing about foam-tac is that it is a super contact cement and thus you let it dry on both faces and then push together to bond. The bond is very strong immediately to allow you to keep building. I suspect it is not as strong as wheite gorilla, but it is easy and quick.
Foam safe CA works well and is quick. But it ius a little brittle and it is exepnsive. it too is quick.
you need many tools. there is no "BEST"
EastCoastGuy is offline Find More Posts by EastCoastGuy
Old Nov 25, 2014, 11:29 AM
RonJ's Avatar
Sparta,WI,USA
Joined Nov 2000
Have had very good luck with this, and I build a lot of foamies.....
http://www.headsuphobby.com/BSI-Foam...ttle-H-500.htm
RonJ
RonJ is offline Find More Posts by RonJ
Old Nov 25, 2014, 01:43 PM
Joined Jul 2014
looks equiv. to Foam-tac, but cheaper. michael
RonJ
Old Nov 25, 2014, 07:46 PM
Challenger 413's Avatar
Dickinson, Tx.
Joined Sep 2004
I used canopy glue on my last couple of foamie builds. Although it takes a long time to dry, the joints are not coming apart. It is a pain to try to sand though.
Challenger413
Challenger 413 is online now Find More Posts by Challenger 413
Old Nov 26, 2014, 08:49 PM
JOHN 3:16
Sammy70's Avatar
Central Ohio
Joined Feb 2008
RonJ
That stuff works 110% great.
My local HobbyLobby has it in stock, and you can use a 40% coupon
Sammy70 is offline Find More Posts by Sammy70
Question Gluing Depron Dragon 2 The Builders Workshop 14 Oct 29, 2010 11:07 PM
Question Gluing Depron Dragon 2 Composites Fabrication 2 Oct 23, 2010 01:39 AM
Discussion Gluing 1mm/2mm depron. sreding Scratchbuilt Indoor and Micro Models 13 Apr 06, 2010 09:20 AM
Discussion Edge gluing depron dmoores Foamies (Scratchbuilt) 11 Oct 23, 2009 05:38 AM
