Old Jun 30, 2015, 06:11 PM
RCRoger2001 is online now
Find More Posts by RCRoger2001
RCRoger2001
United States, MS, Iuka
Joined Aug 2009
Fuse mounted Louvers for Cooling
Hello,
Does any RC Supplier have an assortment of misc sized Plastic or Metal louvers
that can be attached to the Sides of a Balsa or Fiberglass Fuse for cooling ???
I've checked my Elec pwrd Gliders from time to time and when the Air Temp is 95/100 , things get a little Warm in the Mtr/Esc department.
Please let me know, Thanks rcroger
RCRoger2001 is online now Find More Posts by RCRoger2001
Old Jun 30, 2015, 07:13 PM
JimNM is offline
Find More Posts by JimNM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
NACA scoops work a lot better than louvers (unless you are in Virginia...)
http://parkflyerplastics.com/cart/in...roducts_id=278
4.00 for a sheet - great product and very useful.
JimNM is offline Find More Posts by JimNM
Old Jul 01, 2015, 08:06 AM
chawkins is offline
Find More Posts by chawkins
Always room for one more!
chawkins's Avatar
United States, MI, Midland
Joined Jul 2012
Sounds odd but I use plastic spoons, I cut off the spoon a bit from the handle and they come in many colors and cheap
chawkins is offline Find More Posts by chawkins
Old Jul 01, 2015, 08:08 AM
JimNM is offline
WAA-08 THANK FRANK!
JimNM's Avatar
Joined Jun 2002
True, spoons can work. The NACA scoops do not project into the airstream which causes drag.
In the end, Use what makes you happy.
http://www.virginia.org/virginiaisforlovers/ - dry sense of humor in the a.m.....
Old Jul 01, 2015, 10:23 AM
RCRoger2001
Joined Aug 2009
Thanks for the Info guys !!!
Once again, When you need a little Help...................Ask the folks on R C Groups !!
rcroger2001
Old Jul 01, 2015, 11:56 AM
peterlngh is offline
Find More Posts by peterlngh
Joined Apr 2012
One can make a near equivalent of the NACA scoop using a bit from a plastic spoon on the inside of the fuse. Don't forget your exit hole. The general rule of thumb is to have twice the exit area as the scoop. I have also found that some 1/8" diameter holes in the motor mount that line up with the holes in the motor are a great help. That forces the air through the motor instead of around it.
Cheers!
peterlngh is offline Find More Posts by peterlngh
Sold Dlg fuse and stab mount ewers Aircraft - Sailplanes (FS/W) 0 Jun 06, 2015 07:38 AM
For Sale motor mounts for stick fuse type horsefeet Aircraft - Electric - Power Systems (FS/W) 1 Dec 12, 2014 07:45 AM
Sold motor mounts for stick fuse type horsefeet Aircraft - Electric - Power Systems (FS/W) 0 Dec 06, 2014 02:27 PM
For Sale Motor Mount With Cooling Fin For T-Rex 500 Helicopter ucusclub Aircraft - Electric - Helis (FS/W) 0 Dec 02, 2014 02:51 AM
Discussion Louvered end bells/cans for cd motor cooling gpw Foamies (Kits) 7 Mar 01, 2006 05:44 AM
