Old Apr 12, 2015, 07:25 PM
Dave180 is offline
Find More Posts by Dave180
Joined Dec 2012
Build Log
SE5a Hack Morph
I originally built part of the SE5a biplane. Then I changed my mind and just made it a low wing. It flew ok but not to my liking. Now its changing again with a new tail shape and wing from an older kit. The blue wing will be shrunk down and made from foam and newspaper covering.
Dave180 is offline Find More Posts by Dave180
Old Apr 12, 2015, 10:19 PM
springer is online now
Find More Posts by springer
treefinder
springer's Avatar
SE MI
Morph, morph!
springer is online now Find More Posts by springer
Old Apr 14, 2015, 11:26 PM
Dave180 is offline
Joined Dec 2012
Yes! Much faster then starting over. Awhile back, I had made the fuse slightly longer to be scaled with this other blue plane if I went this route. The wing will be slightly wider, longer, and thicker then the one that was on there. Servo's should fit inside.
Old Apr 15, 2015, 09:53 PM
Dave180 is offline
Joined Dec 2012
I made some balsa spars from 1/16" and 3/16" balsa. Should keep it straight. Using the $ tree foam. Rolling the foam with a round tube shipping container.
Old Apr 16, 2015, 07:18 PM
Dave180 is offline
Joined Dec 2012
Made one half. Still need some sanding. The spar tried to warp after I put on one side. I quickly wet the whole spar and it unwarped. It's pretty stiff right now. Should be stiff as a board when I glue the paper back on it.
Old Apr 20, 2015, 07:07 PM
Dave180 is offline
Joined Dec 2012
2 panels made using the water activated white glue. Each weighs 1.15oz after drying out. Going to use a basswood dihedral brace to join them.
Old Apr 24, 2015, 06:30 PM
Dave180 is offline
Joined Dec 2012
A little more progress.
Old Apr 26, 2015, 06:29 PM
Dave180 is offline
Joined Dec 2012
Still going........ I'm a slow builder.
Old May 09, 2015, 10:44 PM
Dave180 is offline
Joined Dec 2012
Still going. Got the big 2.5" tires on there and .078 wire. Wing saddle/dowels redone. Wingtips/servos not installed yet. Wingspan is 35.5"x6"
Old May 17, 2015, 09:59 PM
Dave180 is offline
Joined Dec 2012
Installing the wing servos. Going to glue the balsa blocks in place.
Old May 19, 2015, 10:22 PM
Dave180 is offline
Joined Dec 2012
Retro look wing tips installed.
Old May 20, 2015, 11:52 AM
Dave180 is offline
Joined Dec 2012
About done. Went from 11.5oz to 15oz now. If I upgrade the motor and battery then it's going to be 16oz.
Old May 28, 2015, 02:20 PM
Dave180 is offline
Joined Dec 2012
I pulled the hurc 300 motor out and will replace it with something bigger. It flies ok but the climb out pretty much sucks. It does a wicked death spiral though. The green paint is hard to see at times. Might put some red stripes on it.
Old Jun 03, 2015, 02:19 PM
Dave180 is offline
Joined Dec 2012
I was testing my new motor and got these results.
50g 1400kv motor
3s 500mah, 10.5 amps, 17oz thrust
3s 1800mah, 13 amps, 23oz thrust
I'll use the 1800mah.
Old Jun 22, 2015, 08:38 PM
Dave180 is offline
Joined Dec 2012
It works! Increased the rudder throw some more as the plane is heavier. Still need p-mix on throttle to rudder for straight landings as right thust doesn't work.
SE5a morph2 (3 min 32 sec)
Discussion Phantom 2 - Mod Naza M Lite (hacked M V2) bucket183 Multirotor Talk 2 Mar 30, 2015 09:49 PM
New Product The μHack -DIY Hardware Hacking for Both Beginners and Experts ChaceCarlson DIY Electronics 2 Jan 24, 2015 11:27 AM
Discussion Hack Naza-M V2 --> Phantom 2 Naza Raffi961 Multirotor Electronics 2 Jan 05, 2015 12:48 AM
Help! Futaba 6ex 2.4 G + Chinese 2.4 g hack module. Will it work ? bujora Radios 10 Oct 12, 2013 05:00 PM
Discussion WALKERA 2.4 TX hack -can YOU hack it? aaronstomfoolery Radios 2 Oct 29, 2011 04:44 AM
