Old Mar 25, 2015, 05:52 PM
335driver is offline
Find More Posts by 335driver
335driver's Avatar
USA, TX, Round Rock
Joined Dec 2006
Question
loose motor
Picked up a used FMS FW-190 and the motor is loose. It's easy to wiggle up, down, left and right. I was going to remove the motor and motor mount and build a plywood box to fit in the recess and hopefully reinforce the firewall and steady the motor once it's reinstalled. Sound like a reasonable plan ? Thanks
335driver is offline Find More Posts by 335driver
Old Mar 25, 2015, 06:38 PM
Davy101 is online now
Find More Posts by Davy101
Davy101's Avatar
United States, KS, Leavenworth
Joined Jan 2012
Yeah, though this is a great bird, the firewall and strut legs are weaknesses that require attention. Check out the FW-190 thread; I've recently linked my firewall replacement and someone elses as well. I used two glued sheets of thin ply that I glassed and then gorilla glued in. I installed the new, bigger wall from the top by removing the foam under the plastic top of the cowl.
http://www.rcgroups.com/forums/showt...17976&page=464
Davy101 is online now Find More Posts by Davy101
Found Looing for: uBlox 6M GPS Module dan_ben FPV Equipment (FS/W) 1 Oct 23, 2014 12:00 PM
Wanted looing for an evolution 10cc kremecheze Aircraft - Fuel - Engines and Accessories (FS/W) 1 May 28, 2014 05:38 PM
Wanted Looing for WKM with Hexa frame set with motors & Gimbale for Hero3 dompower Aircraft - Electric - Multirotor (FS/W) 1 Mar 18, 2014 06:30 AM
Discussion Looing for beta-testers for a build site rikonor Scratchbuilt Multirotors 3 Dec 05, 2013 01:53 AM
Discussion "Disgrace" must have been a loo-loo... arbilab Site Chat 28 Oct 10, 2010 12:07 AM
