Old Mar 06, 2015, 10:40 AM
slimefink is offline
Find More Posts by slimefink
Joined Jun 2007
Build Log
Introducing the "Dan Brat"
Dan at "Extreme Gliders" has designed a new slope wing that's
extremely fast but very manuverable. It can combat or DS and
has a very wide wind-lift range.
He's asked me to do a build and I've started that today with posts
starting tomorrow because I'm waiting for the paint to dry
Pictured below is dans proto type.
Lots of lift
slimefink is offline Find More Posts by slimefink
Old Mar 06, 2015, 11:35 AM
Steve 0 is offline
Find More Posts by Steve 0
Slope-a-Dope
Steve 0's Avatar
United States, UT, Draper
Joined Dec 2012
Looks good....and the wingspan is what...36"?
Steve 0 is offline Find More Posts by Steve 0
Old Mar 06, 2015, 11:47 AM
Joined Jun 2007
The wingspan is 48", sorry I should have mentioned that sooner.
Old Mar 06, 2015, 01:48 PM
Redfarren is offline
Find More Posts by Redfarren
foam is fun, but glass is fast
Redfarren's Avatar
United States, CA, Goleta
Joined Apr 2010
Good eye Steve, that one is actually 30" and came in at only 7.3oz here's a pic of the 48" prototype w the 30". The 48" came in at 24oz and he was trying to make it a little heavy, it flew well in 20+ mph for how light it was.
Hope Dan doesn't get mad I showed his build table
James
Redfarren is offline Find More Posts by Redfarren
Old Mar 06, 2015, 02:23 PM
Steve 0 is offline
Slope-a-Dope
Steve 0's Avatar
Joined Dec 2012
I swear if it weren't for the ladder, I was looking at my build area. Same Triangle on my table, same clutter.
They look like carving machines with that big fin and elevons.
Bring on the video!
Old Mar 06, 2015, 09:43 PM
TRISME is offline
Find More Posts by TRISME
It's not going to build itself
TRISME's Avatar
Aliso Viejo,CA
Joined Aug 2005
Yep, looks a lot like my table too, just a little more organized than mine.
Nice looking planform, dig it!
Tom
TRISME is offline Find More Posts by TRISME
Old Mar 07, 2015, 09:53 AM
Joined Jun 2007
Ok, here we go, as shown below the kit comes well packed and complete
with hardware and covering (not shown). You'll also notice that the wing
comes in four sections, this is because of the compound nature of the
airfoil. Because of the wings shape it will build a bit different than your
normal wing construction.
Using goop (love the stuff) and the wing beds glue the outside panels to
the center sections using weights to hold them in position while glue dries.
As you can see I use bags of rice because they form to whatever I'm
assembling and are heavy enough to hold the wing halves in position while
the goop sets up. After the two wing halves are dry goop the sections
together making sure everything lines up and even, let dry overnight.
Old Mar 07, 2015, 10:55 AM
PGR is online now
PGR
Find More Posts by PGR
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
Originally Posted by slimefink View Post
It can combat or DS and has a very wide wind-lift range.
Combat? With a big vertical stab like that?
Pete
PGR is online now Find More Posts by PGR
Old Mar 07, 2015, 11:51 AM
Steve 0 is offline
Slope-a-Dope
Steve 0's Avatar
Joined Dec 2012
Pete
A very short fight.... knock off the others' fins....you win!
Old Mar 07, 2015, 11:55 AM
Joined Jun 2007
I don't know, fast manuverable quick plus good pilot who
knows. Muhammad Ali was all that and according to him
is still "pretty ".
Old Mar 07, 2015, 12:29 PM
droydx is offline
Find More Posts by droydx
Fun ain't cheap!
droydx's Avatar
United States, CA, Santa Barbara
Joined Apr 2003
Pete
Pete,
I totally agree. Looks like a fun, fast frontsider design, though, to me.
I think I'd knock the fin off if I DS'd it too, cause I totally suck at DS'ing!
Keep cranking out the great toys Dan!
Andy
droydx is offline Find More Posts by droydx
Old Mar 07, 2015, 12:47 PM
PGR is online now
PGR
PGR
Low AltiDude
PGR's Avatar
Joined Jun 2004
FWIW I wasn't suggesting that the fin is a bad design and it probably makes the wing track real well. But I've learned from experience that a target like that isn't a good feature for a combat wing.
rePete
Old Mar 08, 2015, 08:37 AM
Joined Jun 2007
the wing rods are next, be sure to "break the glaze" on each rod
by using some sandpaper before the test fit in the wing. The panels
are pre slotted and mine fit perfect, once the rods are glued into
the supplied pre bent tubes glue them into the wing slots once again
using the wing beds to help insure everything ends up strait and true.
Once this is done I start weighing the flight pack stuff and test fitting
everything to get the wing to balance at the recommended CG of
6 1/2" from nose tip. I like to get all the radio gear installed before
I cover the thing with the supplied "new stuff" clear film.
Next move final assembly.
Old Mar 09, 2015, 10:07 AM
Joined Jun 2007
The final assembly went well, covered the wing and tail
then gooped the tail on and left it to dry. I will maiden the
thing as soon as I can. The Dan Brat came in at 14.5 oz.
balanced check out the pics.
So there it is the much anticipated new wing from
extremegliders.com and if history is any indication
the plane should be real fun to fly.
Lots of lift
Old Mar 09, 2015, 02:58 PM
droydx is offline
Fun ain't cheap!
droydx's Avatar
Joined Apr 2003
Mike,
Nice work. Keep us posted on the maiden. Would love to see it fly!
Andy
Discussion Brat engine Richard Cain Engines 3 Jan 10, 2015 08:16 PM
For Sale OS Max,Thunder Tiger,Brat monroec Aircraft - Fuel - Engines and Accessories (FS/W) 0 Dec 15, 2013 04:48 PM
For Sale Vintage repro 1930's Brat .14 ignition engine, like new. nero1156 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Dec 15, 2013 05:43 AM
For Sale Vintage repro Brat .14 ignition engine, like new. nero1156 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Dec 07, 2013 09:50 AM
Discussion optimize 40 daN to 100 daN razavi Jet Turbines 3 Oct 22, 2013 01:10 PM
