Old Feb 04, 2014, 05:54 PM
Lambro is offline
Find More Posts by Lambro
Joined Feb 2013
Question
Servo Resistance Shutoff?
I have somehow grown to almost adulthood with no knowledge of electronics whatever. I am attempting to design a very specialized set of retractable landing gear. It will require the use of a continuous rotation servo, perhaps the Parallax (Futaba 148).
I cannot seem to find any continuous servo that has, already incorporated, a current surge detector, or something that detects when a servo motion has encountered a mechanical stop and will stop the servo at that position before it destroys itself. Want to run out of a standard 4.8v aircraft receiver.
Is anyone familiar with such a servo, or, failing that, a modification to a servo that would accomplish this end?
Lambro is offline Find More Posts by Lambro
Old Feb 04, 2014, 06:05 PM
davidmc36 is online now
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Maybe you could cannibalize these. They have micro switches to stop the jackscrew mechanism at the end of normal travel and safety shut-off if they jam on something and the current goes high they shut off after like a second or so.
http://www.e-fliterc.com/Products/De...ProdID=EFLG330
davidmc36 is online now Find More Posts by davidmc36
Old Feb 04, 2014, 06:09 PM
Lambro is offline
Joined Feb 2013
I will examine that closely, but of course they are very expensive for cannibalization!
Will be looking for about 2 1/2 inches of travel on a worm drive, so there will be a lot of rotations between endstops.
Old Feb 04, 2014, 06:34 PM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
IC. That would be a lot more travel than the Eflight retracts would have.
These would be pretty much ready to go but not cheap either. Not sure what your size range is.
http://store.firgelli.com/category_s/1821.htm
Old Feb 04, 2014, 06:55 PM
Lambro is offline
Joined Feb 2013
Holy Smoke David, though those are expensive, they do seem to be a "right out of the box" solution! They come in various throw lengths and speeds, and would eliminate the need to fabricate a worm drive.
The prototype gear will be one of four supporting a 10-11 lb. aircraft. That is the best thought I have seen so far, despite the cost. Only two of the four gear will require this long throw.
Old Feb 04, 2014, 07:05 PM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
They sure do look like the thing to use for custom gear. I plan to use them when I get to the ATR-42 scratch build. I want to make a scale-like gear for it. With all the length and gear ratio choices you should be able to fit any size model. It will be a seven foot wing-span model.
Also with the PWM actuated variety you could program the speed with servo speed function of your radio, not like the E-Flight that just go at their own speed once activated.
Old Feb 04, 2014, 07:42 PM
Lambro is offline
Joined Feb 2013
I am pretty excited about the possibilities of these David. I found this impressive video on them:
JRP RC - Firgelli Linear Actuators L12-R First Look and Tests (5 min 56 sec)
Old Feb 04, 2014, 07:45 PM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
They are sweet devices.
Discussion Throttle shutoff Frank Hurd 1/2A Planes 3 Nov 21, 2013 03:31 PM
Discussion What is the typical resistance range of a Servo POT ?? CATPart DIY Electronics 11 Apr 24, 2009 08:58 PM
Help! Parkzone Servo motor resistance? Dongo Micro Ready-to-Fly 1 Feb 11, 2009 04:35 PM
Using resisters on servo amp with radio without EPA rogueflyer Aerial Photography 0 Sep 25, 2004 01:13 PM
Water Resistant Servos? Helicool Foamies (Kits) 4 Mar 17, 2003 06:16 PM
