Old Feb 15, 2015, 07:41 PM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Originally Posted by djpilot View Post
I would like to work out if I can use this on some Afro 30A ESC's to run brushed motors and am not sure where to start.
Start by tracing out the circuit to find which pins of the ATMeg8 are used and what polarity signals the FETs require. The Afro ESC looks pretty simple so it shouldn't be hard to do.
Next, edit the macro.def file to match the MCU pin functions to the circuit. Assemble the program (using eg. AVR Studio 4.19) to create a hex file, and download it into the ESC through the ISP pins on the PCB (using a programmer such USBASP).
Finally, test the ESC on a current limited power supply. If you are lucky it works. If not then you have some debugging to do.
One problem you may have - the Afro ESC uses all N-Channel FETs, so I'm betting it uses 'bootstrap' circuits to generate the high-side Gate drive. Therefore it probably won't be able to hold the upper FETs on continuously. You can get around this by not allowing the PWM to go to 100% at full throttle (PWM pulses keep the bootstrap caps charged up).
Bruce Abbott is offline Find More Posts by Bruce Abbott
Discussion Brushless ESC with a brushed motor soprano1 Power Systems 7 May 05, 2012 01:10 PM
Discussion ESC - brushed/brushless emeraldPark Electric Motor Design and Construction 1 Mar 14, 2012 09:13 PM
Found WTT: My Pro Boat Brushless ESC for your Pro Boat Brushed ESC Diegoboy Boats (FS/W) 12 Dec 23, 2011 09:48 PM
need reversable speed control with no delay aaronredbaron Power Systems 0 Jul 31, 2003 04:40 PM
