Old Sep 21, 2003, 06:45 AM
unclemuck is offline
Find More Posts by unclemuck
Test Pilot
unclemuck's Avatar
Birmingham, Ohio
Joined Sep 2003
esc won't work on the throttle channel
I have a Futaba 6 ch computer radio. My problem is that my esc wont work on the throttle channel. The transmitter is working becauce I can put, say, ailerons on that channel and it will control them. Also I can put the esc on my flap channel and control the motor with the rotary knob. The esc is a GWS ics 300 and gws naro 6ch R6N reciever. Really dont want to fly with my flap knob....lol
unclemuck is offline Find More Posts by unclemuck
Old Sep 21, 2003, 09:09 AM
pgleesonuk is offline
Find More Posts by pgleesonuk
UK / Germany
Joined Nov 2001
Two things to try.
Does a servo work if plugged into the throttle channel?
Try reserving the throttle channel.
Paul
pgleesonuk is offline Find More Posts by pgleesonuk
Old Sep 21, 2003, 09:41 AM
imeins is offline
Find More Posts by imeins
imeins's Avatar
Australia
Joined Nov 2002
Do you have end point adjustments etc set for the throttle channel ? Make sure it's able to return to a true minimum otherwise the ESC will not arm.
Ingmar
imeins is offline Find More Posts by imeins
Old Sep 21, 2003, 11:02 AM
Test Pilot
unclemuck's Avatar
Birmingham, Ohio
Joined Sep 2003
Right on guys!! Went and grabbed my dads 4 channel and was good to go. My computer radio had a trim adj. that was keeping it from true min. You guys are awsome and on the ball. Thanks
Old Sep 21, 2003, 07:35 PM
Miami Mike is offline
Find More Posts by Miami Mike
Pompano Hill Flyers
Miami Mike's Avatar
Miami Lakes, Florida, USA
Joined Mar 2003
Double post.
Miami Mike is offline Find More Posts by Miami Mike
Old Sep 04, 2005, 11:22 AM
mullermw is offline
Find More Posts by mullermw
Fremont, CA
Joined Aug 2005
I had the same problem with a GWS T6AII Transmitter (JR/AIRTRONICS), R6N, ICS-300. (Funny to have this problem with all GWS components).
I'm building my first plane and this thread really saved me time and frusteration. Other first timers: Just flip the reversal switch on channel 1 and the problem should be solved.
Thanks a million!
mullermw is offline Find More Posts by mullermw
throttle won't work---do I need an adaptor? spencer6891 Castle Creations 3 Sep 26, 2004 10:38 PM
Alert Two lipo's that won't work on my Piccalo jmctague Batteries and Chargers 1 Sep 21, 2004 10:02 PM
Help Li-ion 2S 1600mah hour won't work on SS PalouseFlyer Batteries and Chargers 9 Mar 01, 2004 07:58 AM
Power supply won't work on your charger? paulpv Beginner Training Area (Aircraft-Electric) 0 Oct 19, 2001 09:38 PM
ESC WON'T WORK? RICH S Power Systems 7 May 17, 2001 09:15 AM
