Old Feb 13, 2015, 10:40 PM
sodapop131 is offline
Find More Posts by sodapop131
Australia, NSW, Newport
Joined Sep 2014
Which controls
I am a newbie with DLG. I have been mostly flying 4 -6 channel electric planes in mode 2.
When I set up a rudder and elevator only glider, do I hook up the rudder to the airelon channel. This would seem more normal to me rather than have my fingers (or thumbs) on both sticks. What is the usual way a two channel DLG is set up.
sodapop131 is offline Find More Posts by sodapop131
Old Feb 13, 2015, 11:09 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Typically you do move the rudder to the aileron channel.
In mode 2, right stick is pitch and roll regardless of what surface you use to produce those motions. On a R/E glider the rudder is your roll surface so it goes on the right stick.
> WHAT GOES ON WHICH STICK ?
http://www.rcgroups.com/forums/showp...63&postcount=6
aeajr is offline Find More Posts by aeajr
Old Feb 13, 2015, 11:19 PM
Joined Sep 2014
Thanks for a quick reply. The link was a very comprehensive answer and it was in line with what I was thinking. It is the most natural way to fly mode 2.
Old Feb 15, 2015, 06:40 AM
JansonL is offline
Find More Posts by JansonL
JansonL's Avatar
Joined Aug 2013
Or better, set the rudder on the rudder channel and mix it to your ailerons. that way both sticks can be used to control.
JansonL is offline Find More Posts by JansonL
Old Feb 15, 2015, 07:27 AM
Wave Glider is online now
Find More Posts by Wave Glider
Kyle Clayton
Wave Glider's Avatar
United States, VA, Dinwiddie
Joined Feb 2008
^^^ this. I do this on all of my R/E gliders.
Wave Glider is online now Find More Posts by Wave Glider
Old Feb 15, 2015, 08:47 AM
aeajr is offline
LI, New York, USA
Joined Mar 2003
Absolutely! If your radio can do this, this is a good approach.
I still move the rudder to the aileron channel as a matter of standard set-up. But I do set up a rudder to ailerons mix so that both sticks move the rudder. As I am a winch launcher and primarily use the rudder to manage the launch it is important that that left stick always move the rudder.
If I want yaw on the launch or in a thermal, I use the left stick.
If I want roll I use the right stick.
Makes no difference if I have ailerons or not, that right stick does the same thing on all my aircraft and the rudder on the left is always active regardless of where it is plugged into the receiver.
Old Mar 01, 2015, 03:37 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
How are you doing with your DLG?
Old Mar 01, 2015, 04:32 PM
Joined Sep 2014
Slowly, weather and some medical work on my right shoulder (my throwing arm) have stopped me for a while, should be back into it very soon.
Question which firmware is on this thing? GC3.1 MOS 2-axis Glb Brushless Gimbal Controller TheQuestor Multirotor Talk 10 Feb 19, 2015 04:35 PM
Question How do I know which flight control boards are compatible with my remote control ? jumpjack Multirotor Electronics 5 Jan 21, 2015 04:38 PM
Discussion Which flight controller to get? snyper1982 Multirotor Electronics 24 Dec 26, 2014 03:43 AM
Discussion Which mini multirotor have maximum control range? ReviewHobby Mini Multirotors 8 Nov 23, 2014 10:09 PM
Discussion Which Flight Controller ?? EliteUAV Multirotor Electronics 2 Oct 16, 2014 01:49 PM
