Old Feb 21, 2012, 01:59 PM
Autotechwagon is offline
Find More Posts by Autotechwagon
Autotechwagon's Avatar
Colorful Colorado Springs, CO
Joined Dec 2010
Buy electric or convert existing glider to electric?
I have been considering picking up the Tower Hobbies Vista EP for the coming spring and summer. My thoughts were basically:
I would like to not set up a highstart
I love balsa gliders
Cheap and easy to get flying
I already own:
Sig Riser 2m
Sig Riser 100
Sophisticated Lady
Mistral 2m
I am planning to sell one or two to get the new plane.
OR
Could I convert one of the existing planes that I have to electric? The one I would prefer would be my riser 2m. It was my first build way back when I was in my early teens.
What would be the best setup to do this conversion?
What do you guys think?
Autotechwagon is offline Find More Posts by Autotechwagon
Old Feb 21, 2012, 02:15 PM
FULLSCALE is offline
Find More Posts by FULLSCALE
United States, OR, Bend
Joined Nov 2004
span!
Here are my thoughts, just offhand.
I don't know the Vista, but from the list I would say the Riser 100 would be the best, assuming the nose would take the gear as well as any of the others. The extra span would best offset the extra weight of an electric system and fly most similar to the pure glider.
Have you considered building another fuse entirely? Buy the balsa and use the original plans that you already have. Then you have the best of both worlds!
FULLSCALE is offline Find More Posts by FULLSCALE
Old Feb 21, 2012, 02:28 PM
ray foley is online now
Find More Posts by ray foley
volare est vivere
ray foley's Avatar
United States, OH, Toledo
Joined Jan 2005
hi there from Toledo
+1, fullscale.
Yeah, the best of both worlds, go for it. Fuselages are easy to build and easier to modify for best fit of e-stuff from the get go.
ciao -rjf
ray foley is online now Find More Posts by ray foley
Old Feb 21, 2012, 02:32 PM
tkallev is offline
Find More Posts by tkallev
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
Bigger is ALWAYS BETTER!
tkallev is offline Find More Posts by tkallev
Old Feb 21, 2012, 04:26 PM
Joined Dec 2010
I had considered the 100, but I never thought of another fuse. Interesting... I would probably build the tail-feathers also. Should I build it out of light ply like the original, or could I build it different?
Ok, any recomendation for motor size, esc, battery?
Old Feb 22, 2012, 12:42 PM
olyman is offline
Find More Posts by olyman
Hi-Start Man
olyman's Avatar
Texas Panhandle
Joined Dec 2004
You should not have to build a new fuselage, just modify the one you have. There is one on the Sig web site and they will talk to you about it. Check out http://www.skybench.com/
http://www.espritmodel.com/index.asp
I think there is a build for a Sig Riser on RC groups.
olyman is offline Find More Posts by olyman
Old Feb 22, 2012, 03:26 PM
Leadchucker is offline
Find More Posts by Leadchucker
AMA7224 LSF1832
Leadchucker's Avatar
United States, DE, Seaford
Joined Sep 2008
Don't be snookered into believing the 'fact' that an electric conversion will be heavier as it don't always happen. I did two conversions, one was lighter and needed some Pb in the nose for balance and one was spot on the original AUW.
Overall strength is not as critcal as string launch sailplane as the stress from the winch in not there. This is not to say to go crazy,but you can lighten up things a bit. I was amazed at the lightness of construction on my first ARF E-sailplane and was a little doubtful at fisrt on whether it would hold up. It's done just fine and the lack of lawn dart spot landings helps as they are not needed even in contests.
The 2M Riser would probably do well with a 450 size motor or if you want some zip on the climb install a 480. I don't have one but judging from the weight and power of similar aircraft it seems right. Motor installs need not be overly built either, I've used 1/8' ply and 1/16" fibre sheet with good results. It does take a bit of fortitude to hack off the nose of a perfectly fine fuselage, however with some planning and a care with a saw it's easy. Side or down thrust is not critcal as you're not running the motor all the tims as in a power plane. Use a little if you feel you need it, I run 0*/0* and have no trouble with the climbs. A bit of extra rudder and down elevator works just as well.
Oh.....and bigger is ALWAYS better.
Leadchucker is offline Find More Posts by Leadchucker
Old Feb 22, 2012, 09:17 PM
Grunta5 is offline
Find More Posts by Grunta5
Who said Kiwi's can't fly!
Grunta5's Avatar
Hawkes Bay , New Zealand
Joined Feb 2008
My 2m wood sailplanes go great with a KDA 22-20L brushless ( about $13.00 from HobbyKing) , 25 amp ESC and a 9x5 prop. Any 3s lipo 1300 to 2200 ( the 2200 balances it nicely) my wanderer (76inch) will climb almost vertical and be at high start height in around 10 to 12 seconds and will do this many,many times on a 2200 lipo...
Ps : my electric conversion made it no heavier than the unpowered version ( 26 oz rtf from memory..)
Ive also used the little FC2822 and that will also fly it very well , just not as steep a climb as the KDA .
Grant.
Grunta5 is offline Find More Posts by Grunta5
Old Feb 23, 2012, 06:35 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
If you like to build AND keep your original glider HS ready, build a new fuse. Yiu can shape the nose to accept the new motor/prop.
Modification of one of you current glider fuse for the motor should not be hard.
If you are going to use an outrunner you need to be sure you have room for the spinning can.
I just looked at the Vista EP. $114? Wow, the price really went up.
If you buy it, you can try that motor set-up using a 2 cell lipo. But I would plan to throw away the motor and ESC. That set-up will give you a poor climb out. You will want to put in a 200 to 300 watt brushless motor of about 900 to 1200 kV spinning a 9 to 11" prop on a 3 cell lipo.
aeajr is offline Find More Posts by aeajr
Old Feb 23, 2012, 03:58 PM
craigrrr is online now
Find More Posts by craigrrr
craigrrr's Avatar
San Diego area
Joined Jul 2006
Grant.
I agree with Grunta5 about the KDA22-20L ("L" for large)motor from HobbyKing.
I have this motor in a 3 meter Mirage weighing about 40 oz. The motor has plenty of power for this plane. With a 3S LiPo, CAM 10-6 prop, it delivers 21.1 amps, 249 watts max. With a CAM 10-8 it will deliver 32.2 amps, 365 watts, but this is above recommended current and I would not do it.
An inexpensive setup is $13.50 motor, $13 Turnigy Plush 30 amp speed controller, $8.00 Zippy 3s 2200mah or 1800 mah battery, plus shipping.
I have been using KDA22-20M ("M" for medium) on Vista and Windfree with great success; these are high quality inexpensive motors.
I always reverse the shaft so the motor is mounted in front of the fire wall. Then, if possible (and it usually is possible), I carve a shroud out of a solid balsa block to surround the motor to make it pretty. But even without this pretty block, you can't detect an ugly nose once it is 10 feet above the ground.
The outrunner in front of the fire wall does two things:
1. Motor runs cool and keeps the heat outside.
2. No worry about spinning cans, cut motor wires on the inside.
Craig
craigrrr is online now Find More Posts by craigrrr
Old Feb 23, 2012, 08:43 PM
Joined Dec 2010
Thanks for the input everyone. I really like the Vista EP, but I don't need another wing to store. I have pretty much decided to build another Riser 2M fuse. I think it would be the best solution as far and the build process goes. Also, I live 10 min from where RCFoam moved to. They are starting to carry alot of the same stuff that Hobby King sells, so I can get my motor, ESC, and Lipo from them.
Old Sep 23, 2012, 10:51 PM
got lift? is offline
Find More Posts by got lift?
LIVE TO FLY, FLY TO LIVE!
got lift?'s Avatar
Joined May 2009
I took a chance on the Vista and I've been very pleased. I posted some info on my brushless conversion in another thread (link below). I'm hitting 700 feet in 30 seconds.
Vista Brushless conversion
got lift? is offline Find More Posts by got lift?
Discussion Cox Hobbies EZ-Bee II - Convert to Brushless electric? Or keep it at Nitro? BladeScraper Beginner Training Area (Fuel) 7 Feb 28, 2016 08:27 PM
Discussion Convert to Brushless or Buy new?? frankiexp Off-road Cars 3 Dec 26, 2011 10:04 PM
Discussion Modeltech ME 109 slope glider convert to electric rcozstyle Australia 0 Feb 24, 2008 05:39 AM
Where can i buy a 3d 40 or 60 size biplane to convert to electric falcon41176 3D Flying 3 Jun 04, 2005 01:45 PM
convert $4.00 sky rider glider to electric R/C propblast Foamies (Kits) 8 Apr 25, 2002 11:42 AM
