Old Sep 23, 2003, 11:01 PM
NewbieX is offline
Find More Posts by NewbieX
Human Like You
NewbieX's Avatar
Colorado
Joined Feb 2001
Foam cutting templates
What can I use for foam cutting templates. Plywood? Cardboard? Aluminum?
I'm working with dremels and hand tools here, so I'd kinda like to stay away from any metal that can't be cut by hand.
NewbieX is offline Find More Posts by NewbieX
Old Sep 24, 2003, 05:24 AM
crvogt is offline
Find More Posts by crvogt
RIP "Long Shadow Flyer"
crvogt's Avatar
Upstate New York-- Rochester, NY USA
Joined Oct 2001
Luan plywood makes good templates, it is cheap and easy to fabricate. I have one of the nice little bench top band saws.. great for cutting the luan and foam..
1/8 inch Aluminum would be great, if you could make them... a CNC laser cutter would be great to make them.. hehe!!
I have used the luan templates to make wings and tails for my Lazy Blue foamies...
Hope this helps
Carl
crvogt is offline Find More Posts by crvogt
Old Sep 24, 2003, 10:15 AM
sylair is offline
Find More Posts by sylair
Toledo, Ohio
Joined Apr 2003
Templates for foam cutting
I found that 1/8 inch formica works very well.Formica is what counter tops are made of can get it at about any hardware store.
Luke..
sylair is offline Find More Posts by sylair
Old Sep 24, 2003, 10:46 AM
CenTexFlyer is offline
Find More Posts by CenTexFlyer
Near Austin
Joined Dec 2001
Roof flashing can be cut with tin snips and the edge polishes up pretty good with a Dremel. the wire catching on the little snags in wood or even formica make for a corrugate wing.
CTF
CenTexFlyer is offline Find More Posts by CenTexFlyer
Old Sep 24, 2003, 11:06 AM
Ben_E is offline
Find More Posts by Ben_E
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
templates
Do you have a printers shop nearby?
Since I have friends in the graphic industry I have been using the thin aluminium plates that is used for offset printing. They can easily be cut with a good pair of scissors (don't use them for anything else... ) Most printers will be happy to give you a few they do mistakes all the time!
I print my wanted airfoil on paper, glue this to the litho plate and cut out. Just a light sand with 400 grid sandpaper and I'm ready to go. I use needlepins to secure the template on the foam, just press it through the template, and I'm ready to go!
Works fine for me
Ben_E
Ben_E is offline Find More Posts by Ben_E
Old Sep 24, 2003, 12:36 PM
DeaninMilwaukee is offline
Find More Posts by DeaninMilwaukee
Motors beat engines!
Milwaukee Wisconsin, United States
Joined Feb 2001
I use thin posterboard. Cheap, easy to cut out and has so far held up well to the heat.
You just cut it out with an exacto.
Dean in Milwaukee
DeaninMilwaukee is offline Find More Posts by DeaninMilwaukee
Old Sep 24, 2003, 12:47 PM
kepople is offline
Find More Posts by kepople
Real Men Fly Pink Planes...
kepople's Avatar
United States, TX, Rockwall
Joined Jun 2001
I use poster board primarily, but you can only cut a few set before they have to be replaced. I have used, luan or other ply woods, but san the edges for burrs.
If you are cutting wing cores, you will want a more ridgid structure than posterboard will provide so use ply for that
Anything non plastic works very well.
Kirby
kepople is offline Find More Posts by kepople
Old Sep 24, 2003, 08:44 PM
NewbieX is offline
Human Like You
NewbieX's Avatar
Colorado
Joined Feb 2001
Thanks Gents. It's off to the hobby/hardware store once again. I just got a little hotwire rig going and have collected a room full of foam.
First project: Warmliner. Maybe based on the AZ Shrike, but without the bluecor.
Old Sep 24, 2003, 11:05 PM
Robbie d is offline
Find More Posts by Robbie d
Crazy Cessna Owner
Robbie d's Avatar
Australia, SA, Windsor Gardens
Joined May 2001
the best technique i've used, is to cut them out of wood, even hard balsa works. sand the edges smooth, coat edges with ca. sand again, more ca, then final sanding. very smooth and no catches
Robbie d is offline Find More Posts by Robbie d
Old Sep 24, 2003, 11:40 PM
Damien is offline
Find More Posts by Damien
Vertically Challenged
Damien's Avatar
Joined Sep 2003
Print Shop
Thx Ben,
Never even thought about that! And I used to work in a printshop..LOL Gonna have to stop in and visit them REAL soon
Damien is offline Find More Posts by Damien
Old Jun 28, 2016, 10:01 AM
RotoTillerGuy is offline
Find More Posts by RotoTillerGuy
United States, CA, South El Monte
Joined Nov 2009
I use a CNC router to cut Formica/Masonite templates.
Phenolic is even better material, but much tougher to find. Lasts the best.
BTW if anyone needs custom airfoils in custom chord lengths let me know ? $35.00 for two bottoms and two tops, out of Formica.
RotoTillerGuy is offline Find More Posts by RotoTillerGuy
Old Jun 30, 2016, 04:14 PM
Grantham Kid is offline
Find More Posts by Grantham Kid
Chasin' that Neon Rainbow
Grantham Kid's Avatar
Australia, QLD, Grantham
Joined Oct 2012
This thread is 13 years old I doubt anyone is still around.
Grantham Kid is offline Find More Posts by Grantham Kid
Latest blog entry: A bit about me
HOWTO: Foam cutting templates - 5 minutes each MAX! FlightofSong Hand Launch 6 Jun 28, 2016 10:57 AM
Foam cutting templates - What material? tomlin Electric Plane Talk 14 Jun 28, 2016 09:55 AM
HOWTO:5 minutes to perfect foam cutting templates! FlightofSong Foamies (Kits) 3 Jun 29, 2003 02:15 PM
