Old Sep 02, 2014, 10:34 PM
Joined Sep 2014
AR636 and Leader 480
Hi,
I recently purchased the AR636 and got it installed into a Leader 480. However I'm hesitating with the programming. I simply do not know what configuration will work well with the leader 480. Can anyone help?
Creepy
CreepyCrum is offline Find More Posts by CreepyCrum
Old Sep 03, 2014, 05:27 AM
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
It just looks like a normal 4 channel airplane, if it has seperate aileron servos you may wish to run them on seperate channels to enable differential and other things related to a Dual Aileron Wing type.
When you start with the Setup Menu and follow the list of functions it should get you setup fairly quickly and easily.
When you pick your Wing Type check out the Servo Monitor screen and make your servo connections according to the renaming of channels, for example the when using a Dual Aileron Wing Type the Aileron channel will now be labeled RAL and the Aux1 will be LAL.
freechip is online now Find More Posts by freechip
Old Sep 03, 2014, 09:36 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
It flies great without stabilization! So unless you reeaaaallly screw things up, you'll be fine.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Sep 03, 2014, 07:15 PM
Joined Sep 2014
That's the fear factor, I simply do not know what values to enter.
I'm using the Dx5e with the AR636. However the configurations its done through ipad.
I would like to setup a moderate flight mode. However, I may end-up replacing the AR636 for the AR636 safe.
Old Sep 04, 2014, 08:49 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
If you can fly a T-28, you can fly a Leader.
Andy
Site Sponsor
Sold Eflite Leader 480 RedCaptain10 Aircraft - Electric - Airplanes (FS/W) 3 Apr 22, 2014 09:59 PM
For Sale E-Flite Leader 480 thfirefighter479 Aircraft - Electric - Airplanes (FS/W) 5 Nov 06, 2013 07:54 PM
Sold E Flite Leader 480 BNF $250 mdtang Aircraft - Electric - Airplanes (FS/W) 13 Nov 04, 2013 02:43 PM
Discussion E-flite Leader 480 for sale rpstar Atlanta Area RC 3 Nov 03, 2013 11:28 AM
Sold Eflite Leader 480 RX ready LPU Charlotte,NC Brad Peters Aircraft - Electric - Airplanes (FS/W) 2 Sep 28, 2013 02:23 PM
