Old Sep 01, 2014, 01:53 PM
Joined Aug 2014
Help!
Losi SCT 1/24 quits after a few mins
My Losi SCT truck has the brushed motor, 27 mhz and a lipo. The truck works fine for a few mins, but then begins to hesitate and slowly stops moving. I assumed it was the battery, but after testing, turns out the battery is fine. I brought it to a local hobby shop where they told me it was likely the radio. Can anyone tell me if they've had this problem? I question whether it's the radio because the steering servos keep working after the motor stops. Could this be an overheating motor or something similar? Just don't want to buy a new radio to find out the one I have is fine. Any suggestions would be great.
JB05 is offline Find More Posts by JB05
Old Sep 01, 2014, 07:19 PM
Brazil, SC, Brusque
Joined Aug 2012
Hi, is it a totally stock brushed SCT?
Where are you running?
Plush carpet can make your motor overheat fast.
Try it on a smoth surface with half trigger and check if it takes longer to slow dow.
Artur Fischer is offline Find More Posts by Artur Fischer
Old Sep 01, 2014, 10:18 PM
Joined Aug 2014
Thanks for the reply Artur. I'm only running it on hardwood floors or pavement with the same result. And the only upgrade is the lipo.
Old Sep 02, 2014, 02:29 AM
West Virginia
Joined Apr 2010
I think Artur's suspicions are correct but I'll go ahead and ask a few questions in the meantime.
What lipo are you using? How did you test your lipo? What voltage is it when fully charged? What voltage is it right after the run? What voltage is it after it rests for 5 minutes after the run? How many mah is the battery and how much is the charger putting back in?
Dialed_In is offline Find More Posts by Dialed_In
Discussion The Losi 1/24-scale 4WD Micro SCT and Rally Car Bowerz Micro Cars 706 Oct 11, 2014 01:06 PM
Discussion Differential fluid for Losi Micro SCT 1/24 bfs325 Micro Cars 3 Mar 23, 2014 09:45 PM
Sold Losi 1/24 SCT and Losi Micro Crawler - Reasonable offers considered PontiusPilate Cars - Cars and Parts (FS/W) 4 Nov 12, 2013 05:08 PM
Wanted Losi 1/24 micro SCT pilot1211 Cars - Trucks and Parts (FS/W) 3 Oct 25, 2013 02:16 PM
