Old Dec 19, 2009, 10:54 AM
Joined May 2007
DX450 Axle Bearings DTXC4422
Okay - so I learned the hard way that those rear axle screws need to be removed and loctite applied right out of the box. That said I've managed to lose one of the axle bearings. DTXC4422 is not in stock anywhere I can find. Backordered everywhere until January - So looks like I'm down until then.
In the mean time I'm wondering if there is a similar washer out there or some other mod that someone else has already found to get going again. Any thoughts or suggestions are appreciated.
Also - since I'm going to be ordering parts - any suggestions on absolute need to haves for the pit box?
riceman is offline Find More Posts by riceman
Old Dec 19, 2009, 04:46 PM
Just an rc junkie
Surrey, BC, Canada
Joined Jan 2005
Those look so close to the little spacers used on an fg gear cover. I'll pull mine out and have a look as I have some extra gear cover spacers here to compare it to. tower sells the duratrax one cheap and it comes with them. where are my calipers...
Pipeous is offline Find More Posts by Pipeous
Old Dec 22, 2009, 02:41 PM
Joined Dec 2009
riceman, you have a PM.
Noff is offline Find More Posts by Noff
Old May 16, 2010, 03:19 PM
Sorry Im a Noob!!!
Hawaii
Joined Aug 2006
im just currious for i had lost mine too. did you ever find a simalar part to replace it?
intelik808 is offline Find More Posts by intelik808
Old May 18, 2010, 10:22 AM
Just an rc junkie
Surrey, BC, Canada
Joined Jan 2005
I had made my own until I got my back order. I just used a washer and for the lipped part a small brass spacer the same size as the inner bearing race. worked good.
my bike is down now until I get an axle. I busted a bolt off inside the axle
Discussion M5/DX450 Wraps, More Tail Saver, and Action Shots Guidoracer Motorcycles 39 Dec 17, 2009 08:30 AM
Wanted ALUMINIUM Axle Housing Cover for TXT-1 junglew Cars - Cars and Parts (FS/W) 0 Nov 11, 2009 01:16 PM
Discussion Using a Gyro on the Roll Axle rimshotcopter Mini Helis 17 Nov 02, 2009 04:16 PM
Wanted RC10 Rear axle carrier bearings Rys2k8Altima Cars - Cars and Parts (FS/W) 1 Feb 07, 2009 12:13 AM
For Sale FS: 2030 smart lipo/nimh charger, AL hub, AL axle, ball bearings for Mini-T built2scale Cars - Cars and Parts (FS/W) 9 Feb 08, 2006 11:23 PM
