Old Oct 17, 2014, 06:05 PM
Dave K is offline
Find More Posts by Dave K
Dave K's Avatar
Sebastopol, Ca
Joined Jun 2004
Wow that is a great plane. Looks soooo good in the air. Thanks for posting the video.
Dave K is offline Find More Posts by Dave K
Old Oct 17, 2014, 07:08 PM
Dmerino is offline
Find More Posts by Dmerino
Pollock Pines, CA
Joined Aug 2002
Great job, Gupi. She is absolutely beautiful in the air. The video looks like it could be an old black and white movie somewhere on the front lines. She really flies smooth.
I've got one question for you, please. How far back from the leading edge of the upper wing did the balance point check out at?
I built a smaller, printed paper on 1mm and 3 mm foam, DVII. I worked off of some 3 view drawings which showed the balance point as being just about threw the centerline of the landing gear wheel. It's taken a lot of weight to get this close. She hasn't maidened yet. I was wondering if you could give me the dimension of your balance point? It would truly be appreciated.
I'm attaching a couple of pics for your review.
Thank you,
Dennis
Dmerino is offline Find More Posts by Dmerino
Old Oct 18, 2014, 02:23 PM
gupi is offline
Find More Posts by gupi
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
Thanks guys!
Dennis, I've attached two screen shots of two separate Fokker D.VII i built that show the balance points. Both fly very well. I hope it helps.
gupi is offline Find More Posts by gupi
Old Oct 18, 2014, 02:41 PM
Dmerino is offline
Pollock Pines, CA
Joined Aug 2002
It certainly does, Gupi..
Thank you very much.
Dennis
Originally Posted by gupi View Post
Thanks guys!
Old Oct 18, 2014, 02:53 PM
Dmerino is offline
Pollock Pines, CA
Joined Aug 2002
Gupi,
I just used your graphics with dimensions for the C/G and calculated the equivalent for my scale and it turns out to be spot on.
Thank you again.
Dennis
Old Oct 18, 2014, 04:11 PM
gupi is offline
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
Cool! Good luck for the maiden!
Old Oct 19, 2014, 04:25 AM
SubManEric is offline
Find More Posts by SubManEric
SubManEric's Avatar
Joined Mar 2010
Gupi,
I loved your video. What a beautiful plane and very well flown as well. Thanks for posting.
Eric
SubManEric is offline Find More Posts by SubManEric
Old Oct 19, 2014, 06:23 AM
moscow580 is online now
Find More Posts by moscow580
Is it suppose to do that?
moscow580's Avatar
USA, CT, Waterbury
Joined Sep 2006
Gupi
Just saw the video. Whatta floater. Don't be nervous - you flew her beautifully. Just enjoy now.
Sean
moscow580 is online now Find More Posts by moscow580
Old Oct 22, 2014, 07:52 PM
RITTMEISTER is offline
Find More Posts by RITTMEISTER
Bipes Rule!
RITTMEISTER's Avatar
United States, LA, Pearl River
Joined Feb 2006
Fokker crazy
Gupi I am glad I finally got to see the Fokker in action!!i like the video and music. What mode are you flying? Aileron and elevator on same stick? I fly aileron / throttle on same stick( left stick ) The stabilizer on your Fokker does not hang down whatsoever !! What degree incidence you have on the stab?? Must be positive. I add 1* positive on stab previous builds but next plane maybe add more. Yours definently flies more scale than mine. Great job. I think I finally got to see what you look like on the video. I was curious over the years I have followed you how old you were
Friends in Fokker's
Dennis
RITTMEISTER is offline Find More Posts by RITTMEISTER
Old Nov 02, 2014, 02:05 AM
gupi is offline
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
I'm glad you like the video!
@Dennis:
Mode: I'm flying mode 2 (throttle and rudder on left stick).
Angles: I've measured them in Peter Rake's plan, top stringer used as datum line.
Top & bottom wings: +2.6 degrees (profile center line)
Stabilizer: +1.5 degrees
I hope that helps!
Old Nov 02, 2014, 08:12 AM
Bipes Rule!
Joined Feb 2006
What was the thrust angles on motor and the AUW? Thanks
RM
Old Nov 02, 2014, 02:40 PM
gupi is offline
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
Thrust angles are 2 degrees right and down. The AUW is 3.5 kilograms (about 7.7 pounds).
Old Nov 02, 2014, 10:50 PM
Bipes Rule!
Joined Feb 2006
Thanks gupi
Old Jan 13, 2015, 09:43 PM
Brooks is offline
Find More Posts by Brooks
Damp and Dizzy member
Brooks's Avatar
Bozeman, Montana, United States
Joined Aug 2003
You might enjoy this nice article on finding biplane cg by Alasdair Sutherland. "Page 1, Page 2, Page 3" are the parts you want to download from Colin Usher's Center of Gravity article (which deals with all sorts of planes, not just biplanes). urls are in this page, under paragraph "Biplanes and other multi-wing aircraft."
http://www.colinusher.info/model%20aircraft/centre.html
Brooks is offline Find More Posts by Brooks
Old Jan 14, 2015, 02:36 PM
P_J_Glor is online now
Find More Posts by P_J_Glor
P_J_Glor's Avatar
Valencia, CA
Joined Oct 2002
She is really lovely and shows the results of your craftsmanship and Peter's design (And, of Course, Anthony Fokker's original design). What a great model. So nice to see that it can be shown in her element where she belongs. Now get some SE5's or Camels or SPADs to come out and play, too (if they dare!)
Pete G
P_J_Glor is online now Find More Posts by P_J_Glor
Build Log Peter Rake 1/6 Fokker D.VII - re-built Pat Lynch Scale Kit/Scratch Built 745 Mar 07, 2015 02:13 PM
Sold Hangar 9 Fokker D-VII ARF NEW nero1156 Aircraft - Fuel - Airplanes (FS/W) 3 Jan 21, 2013 06:34 AM
Discussion Peter Rake Fokker D.VII Wolpertinger Scale Kit/Scratch Built 296 Nov 07, 2010 06:11 AM
Fokker D VII by Peter Rake Ian Easton Scale Kit/Scratch Built 158 Dec 21, 2005 11:06 AM
Peter Rake's Fokker D-VIII Jim Drissell Scale Kit/Scratch Built 12 Aug 02, 2002 01:10 PM
