Old Aug 04, 2012, 02:25 PM
easyrider604 is offline
Find More Posts by easyrider604
Canada, BC, Port Coquitlam
Joined Apr 2012
EPS foam in EDF jet models
Tried the search function but couldn't find the answer, so I hope you can help me.
Why are some EDF jets still made from EPS foam when most airplane models now are molded from EPO?
Is EPS better for EDFjets than EPO?
easyrider604 is offline Find More Posts by easyrider604
Old Aug 04, 2012, 05:04 PM
Eddie P is offline
Find More Posts by Eddie P
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
It's very light weight, cheap and easy to make changes to. Not as crash worthy of course as EPO!! However, the standard EDF is not very crash worthy no matter what the construction - fans explode and fast thin wings shatter when you pile EDF's into the ground. So EPS derivatives can still be of use for some.
If I'm going to glass a foam model I actually prefer working with EPS as a base for modifications and glass work. If I'm going to pull a completed ARF out of a box and fly completely unmodified, then EPO has advantages.
Eddie P is offline Find More Posts by Eddie P
Discussion Model Plane Foam in the new model avation gard72977 Foamies (Scratchbuilt) 20 Aug 07, 2012 10:12 AM
Sold Edf jet kits & RTF edf jets- LPU Sacramento sweintraub Aircraft - Electric - Jets (FS/W) 6 Jun 27, 2012 11:31 AM
Wanted Sapac Foam T-45 64mm EDF jet thndr1mj Aircraft - Electric - Jets (FS/W) 6 Mar 15, 2012 12:20 AM
Question Need FMS Model of small EDF Foam Jet demisemiquaver Simulators 0 Feb 13, 2011 02:42 PM
Discussion Kmp F-18 Eps Foam Edf Jet PREACHHAMES Foamy EDFs 120 Feb 20, 2007 08:28 AM
