Old Sep 09, 2009, 10:02 AM
kneekolaas is offline
Find More Posts by kneekolaas
Joined Apr 2009
Build Log
Nice stunt plane (full fuse Cap.. extra...) type platform
A while ago i bumped into a nice Bipe build... "Micro Ultimate" excellent plan.. cheeers to whomever it was that designed it...
.........................so i built a bigger version:
flies great... so built about 3 different sizes from 600mmWS to 1100WS..
then built a midwing version..............
That flies great to...(needs bigger ailerons..but great at speed)
so am now using the same fuse platform for an extra style midwing @ 1170mmWS
as you can see ..a fair bit bigger....
Hers a few pics of how shes going together so far....
will be the biggest WS i have made to date...
if she comes out OK i will post the tiled and untiled plans here somewhere...
Not sure if the PA Thrust 20.... or the 30 should go in it..............?
kneekolaas is offline Find More Posts by kneekolaas
Old Sep 09, 2009, 10:06 AM
cmelton11 is offline
Find More Posts by cmelton11
CMelton
cmelton11's Avatar
USA, NC, Burlington
Joined Jul 2009
yeah post them here I like the looks of it I would love to build it
cmelton11 is offline Find More Posts by cmelton11
Old Sep 09, 2009, 11:42 AM
Jrphillips is offline
Find More Posts by Jrphillips
Jrphillips's Avatar
Joined Aug 2009
Me too!! ALSO LOOKING for the Edge 540 full fuse and wing etc.. sem
Jrphillips is offline Find More Posts by Jrphillips
Old Sep 16, 2009, 12:26 AM
Joined Apr 2009
Have done a fair bit to it now. Carbon in tail and set... The whole plane has been hot glued so far... That hot glue is cool stuff...
Hole in wing tip where sharpened carbon tube came thru
Guides for wing hole fuselarge cuts.... and also inner supports... helps to make these before the wings are joined...just trace the widest part of the wings.
Get approx position with them on outside pins
Once holes in fuse are cut they become supports
Got carried away and forgot to take picks while making the cowling..... a bit rough and simple but looks kinda warbirdish and cool... will have carbon exhaust ports soon...that will look very cool i reckon
ailerons are proving to be a challenge... havent done any this thick before.... I wanted them to have alot of travel forslowflying hovering and 3D etc but they dont travel much yet...enough for speed runs but not slowflying... Help here would be nice.. Anyone Know a technique or have a link....???????
Pretty happy with it so far.. big at 1170mm wingspan..looking cooler than i expected... about 20hrs into it sofar... but alot of extra....
"how the hell am I going to do that" time in between.. This is only my 7th scratchbuilt... and only been flying about 6 months....so far from knowing it all
Also .....going to try a 281220? Himax on 4 cells...or maybe a Thrust20-30 on 4cells (4s 25c 1750)
Anyknow the typical amps draws?????? prop size?????/
Old Sep 16, 2009, 12:48 AM
Joined Apr 2009
plans will be posted when i figure out how to scan them in to scale
Old Sep 18, 2009, 09:19 PM
Joined Apr 2009
k... finished and maidened.. alllmost perfect maiden.. a little heavy landing.... to slow then she stalledbout a foot off the ground.. very little damage...
very happy with it tho...
Flying weight is 750 grams.. is that light for a 1200mm WS plane..????
360 watts
34amps
281220 himax (i Think only rated to 20 amps)
40 PA esc
11x5.5 APC prop
and a 3s 2200 zippy... was sucking it down to 10.5 VM and WOT....!!!
so yeah....veeerrryyy happy with her flew great... veerry responcive but stable... very big to fly in the paddock beside my house... very fast too when you give it full throttle... i lost the cock pit at one stage and the drag was instantly apparent...
like i said plans go up here when i figure out scanning... they are basically micro ultimate plans with a extra 300 wing.... thanks again to the guys that desighned those 2 plans.....
Old Oct 13, 2009, 07:34 PM
Joined Apr 2009
OK... been having heaps o fun with it... flies great
been running a himax 28 12 20 (max 20 amp) 1220kv ...i think
has been nice at :
3s
360 watt
35 amp
11x5.5 APC
but...... try a 4 cell at it rocks....!!!!
566 watt..!!!!!!!!!
38.5 amps
14.6 min volt
8x8 APC
4s 2600 zippy
only 4 for amps and i get 200 more watts... and waaayyyyy more speed......
have to be 25% more top speed....at least.....
Old Feb 05, 2010, 03:27 PM
Joined Apr 2009
If anyone wants the plans ( which include the original bipe wings) send me a PM with your email address... plans are formated for A4 printer
I would post the planes but dont know of a host to upload the PDF files to
Old Feb 05, 2010, 11:45 PM
GreenAce92 is offline
Find More Posts by GreenAce92
Physics hate's my ideas
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
Hey nice plane! BTW what is the first motor you have on there? A BPhobbies Axi type motor? (not by Axi but it looks like it)
I like the transition very nicely done
GreenAce92 is offline Find More Posts by GreenAce92
Old Feb 06, 2010, 07:45 PM
Joined Apr 2009
ummm. the 1st couple of small planes have a hobbyking motor on them ...i think its a turnigy 24 04 14
the blue motor is a himax
now running a turigy 35 42 on the big mid wing with an 8x6 on 4s at about 60 amps... reallllly moves now
Old Apr 14, 2015, 02:07 PM
julianoveloso0 is online now
Find More Posts by julianoveloso0
Joined Apr 2015
Please, send to me the plans? juliano_veloso@hotmail.com
julianoveloso0 is online now Find More Posts by julianoveloso0
E*Star 3D Cap, Extra, and Sukhoi Build Thread Bill K. 3D Flying 310 Oct 05, 2009 12:44 AM
Electrostreak ARF-Jeti 15/4 very nice flying plane Dave Grife Sport Planes 3 Apr 27, 2002 09:25 AM
Sky Shark Stunt Plane istrebitelace Foamies (Kits) 1 Feb 13, 2002 08:39 AM
Any EPP Cap, Extra or Sukhoi planes out there? aeox Foamies (Kits) 2 Jan 22, 2002 10:03 PM
K&A models Mig 15- first flight- nice flying plane Dave Grife Electric Ducted Fan Jet Talk 41 Sep 09, 2001 02:55 PM
