Old Aug 15, 2015, 06:49 AM
Yehya is offline
Find More Posts by Yehya
Joined Apr 2008
High temp casting resin
Need a casting resin that will resist 500 degrees Fahrenheit for an hour when cured, that I can buy in smaller quantities, and cures at room temp?
Yehya is offline Find More Posts by Yehya
Old Aug 15, 2015, 11:21 AM
Yehya is offline
Joined Apr 2008
Maybe aluminum filled?
Old Aug 16, 2015, 12:50 AM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
That's a tough one. The high temperature ones that I know of need high temperature cures.
Most of the aluminum filled ones I know of are pushing their limits at 500 F. High temperature JB Weld is similar to some of the REN brand products. It can go to 500 F, but not sure how long it will last as a mold at that temp.
Another option I know of is high temperature RTV silicon, like Mold Max 60. Since it is flexible it might need supported, depending on what your doing.
Roto Rob is offline Find More Posts by Roto Rob
Sold Cast resin radial engine nero1156 Aircraft - General - Miscellaneous (FS/W) 1 Apr 18, 2015 12:40 PM
Sold Ciba Aluminum casting resin 6gal. FlyDLG Aircraft - General - Miscellaneous (FS/W) 1 Oct 28, 2014 03:19 PM
Alumilite Casting resin mrbaseballny The Builders Workshop 2 Mar 23, 2005 10:03 AM
Casting resin.........Help elsyau Submarines 8 Mar 18, 2005 06:58 PM
Casting parts with polyester resin epilot Composites Fabrication 0 Jan 10, 2005 07:14 PM
