Old Jul 18, 2014, 03:48 AM
Did you check the FAQ already?
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
I have received the mclaren body, looks darn good! Mounting it is a pain though, one mounting bracket needed to be cut as it pressed against the motor can. Now it fits great but still hard to put on or remove. I may need to work on the mounting brackets a little more.
SoloProFan is online now Find More Posts by SoloProFan
Old Jul 18, 2014, 01:37 PM
Sakura Ultimate graduate
SporadicIdiocy's Avatar
Richmond B.C. Canada
Joined Oct 2007
I trimmed the clips on either side, easier to put on. I've been looking to get the body posts parts to use the Mini-Q lexan bodies for some more weight savings.
SporadicIdiocy is offline Find More Posts by SporadicIdiocy
Old Jul 18, 2014, 01:46 PM
Nice
Joined Nov 2008
What is the best shop for international shipping to buy the Atomic car guys
Helicoy is offline Find More Posts by Helicoy
Old Jul 18, 2014, 01:53 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
I did the same, first cut the large square flat parts and then used a sanding tool to remove some of the remainder of the clips. It now fits on with a little pressure. I'm a little reluctant to remove any more material, and make the fit too loose.
Also drove it with body, seems better than without. The motor was a bit warm after 5 minutes of running, might be the carpet I was running on. It's also quite warm here, both outside and inside.
Also noticed the car slows down almost instantly after releasing throttle. Is this normal? I know it has little mass to keep rolling, and I doubt it's the drag brake setting, as the car also stops directly after being pushed forward manually. Might also be the motor's magnet pull, the stronger the magnets, the more natural braking.
I would think Xtreme, they are good to deal with.
Old Jul 25, 2014, 06:14 PM
Joined Oct 2007
Just ordered the bumper and body mount set along with two mini-q bodies. Got the Porche and the Ferrari. This car is already pretty light compared to the mini-z, I'm hoping this will lighten it even further.
Old Aug 06, 2014, 09:55 PM
Joined Oct 2007
Well I guess the car is too light and there isn't enough mass/momentum to keep the motor rotating for very long. The car does roll noticeably further with a body on.
The alloy bits I ordered finally came in! Spent an hour or so installing them, finally happy with the car lol.
Now I just have to wait for the lexan bodies and I'm done with upgrading this car. I'll be focusing more on my 1/10 for now, Mini-Z season is months away still.
Anyway, I've come to the conclusion that the stock servo saver sucks. The O-ring doesn't hold the servo horn in position that well unless you tighten the screw real hard, and by then the functionality of a servo saver is gone. Might as well switch to a solid servo horn if you're using the digital servo, you'll have much more precise steering. Just don't hit anything hard lol
Old Aug 11, 2014, 10:59 PM
Joined Oct 2007
The bodies arrived!! The pre painted porsche body fits pretty nicely, though the front body post of the atomic parts set is a little too short, will have to get the Mini-Q body posts in order to mount it properly. I guess I can rig up some velcro mounting method on the front somehow.
The car is now a full 32 grams lighter than my Mini-Z AWD. Pretty nice considering my Mini-Z AWD with an ASC body is 183 grams.
Old Sep 15, 2014, 11:41 AM
r46
huggin dat apex!
r46's Avatar
United Kingdom, London
Joined May 2005
Fitted spare ko micro rx too gauge steering response over gt3c so much so went an got gogo laps asf rx,received it Saturday an straight away have issue lol. What have thought would come with some form of instructions for unit ie how to set it up
The pins are configured different to digi servo so will have too swap pins around before get a burnt servo
r46 is online now Find More Posts by r46
Old Sep 16, 2014, 08:29 PM
Joined Oct 2007
Nice, how much is the gogolap Rx? I'm pretty happy with my car right now, only thing left to tinker with is the servo saver which I think is the source of some stickiness in steering.
Once that's done I'll switch over to an RX-381 to use my MT-4 instead.
Old Sep 17, 2014, 12:40 AM
r46
huggin dat apex!
r46's Avatar
Joined May 2005
was $78 an its faulty (not powering up)
i had stickiness in steering too which was caused by one of the pillow balls in arm not moving freely.
Old Sep 19, 2014, 02:42 AM
Joined Oct 2007
Ah so it's not working at all? Hopefully it's just an unlucky draw.
I'm pretty much done with hop-ups on this car, all that's left is some fine-tuning. Besides, I've already spent way too much on this car lol, though I am very happy with how it handles now.. What started as an attempt to cheap out on upgrading my MR-03 ended up costing me about the same haha.
Old Sep 19, 2014, 10:11 AM
r46
huggin dat apex!
r46's Avatar
Joined May 2005
Replacement rx has arrived to shore so hopefully get tomorrow, bulkheads is next upgrade as had bearing cover pop off few time now lol
Discussion Turnigy TZ4 AWD 1/28 Mini Touring Car shahram72 Micro Cars 184 Oct 13, 2014 08:53 PM
For Sale Kyosho Mini Z AWD RTR latinflyer Cars - Cars and Parts (FS/W) 3 Jul 11, 2013 05:57 PM
Discussion Flying Dog/AWD Afriel Ultra Build Thread F3P Connor Indoor Pattern/F3P 42 Mar 24, 2013 02:46 PM
Sold Compass Atom 500 mike3488 Aircraft - Electric - Helis (FS/W) 1 Feb 03, 2013 01:17 AM
