Old Sep 30, 2014, 06:09 PM
Edhs's Avatar
the seventh planet
Joined Dec 2010
I can concur that the Pyro fuse is tough to get right. I used 1105Neu and a 1300/65C thunederpower as far back as it would possibly go and still had to add tail weight.
It did fly amazing and was a terrific model though.
Sorry for the off topic
Edhs is offline Find More Posts by Edhs
Old Oct 02, 2014, 05:18 PM
United States, AL
Joined Apr 2007
Originally Posted by ehelibuff View Post
The Jolt 2 is tight too once you get everything in there. Comes out very tail heavy, so you need to put everything forward and add lead. .....
You have a 5s 2700 pack AND a nimh rx pack in it and you say the fuselage is tight?!?!
If only there was a build thread where somebody built one a couple years ago and posted about how you need a split pack to easily get the CG forward enough even with a heavy motor. Oh wait, that's this thread!
biskit is offline Find More Posts by biskit
Old Oct 02, 2014, 05:22 PM
ehelibuff
ehelibuff's Avatar
United States, CA, Santa Clarita
Joined Aug 2014
I didn't get a split pack. Just 1 brick.
ehelibuff is offline Find More Posts by ehelibuff
Old Oct 02, 2014, 07:51 PM
Edhs's Avatar
the seventh planet
Joined Dec 2010
Glad you did your homework lol
Old Oct 02, 2014, 08:00 PM
ehelibuff
ehelibuff's Avatar
Joined Aug 2014
The new battery is a lot smaller than before. If it wasn't for my oversized ESC, I could slide the battery forward. It's a 150A with a big heat sink with cooling fins. Bulky, but it doesn't get hot. I'm going to test some new props this Saturday.
Old Oct 05, 2014, 12:34 PM
ehelibuff
ehelibuff's Avatar
Joined Aug 2014
Jolt 2
Well, I had a mishap on Saturday. I was testing the plane with an APC 5x5 prop. Around the 50 second mark, I was about to shut the motor off, when the motor shut itself off... I thought maybe the spinner flew off the motor perhaps? So I cut off power and set up my landing. I had to land on the opposite end of the field, so upon landing, my stab found a gopher mound and busted the stab a bit as you can see in the picts. I'll need to order a new stab. The running gear was very hot this time, unlike before with the GM 5x5 set up. I smelled a burnt smell inside. So, I think the ESC popped. Hopefully the motor is ok. Being a 150A esc, I thought would be fine. I find it surprising that the APC pulled that much more on everything?? Do I need a 200A? I even had the BEC disabled with the pos lead removed, which should bump me up even more from what I understand. Bad luck for me.... I hope I just need a new ESC and stab. I'll send in the motor to Steve Neu to check it out. Hate to think the motor toasted in 3 runs on a proper set up. Bummer weekend for me......
Old Yesterday, 12:52 PM
ehelibuff
ehelibuff's Avatar
Joined Aug 2014
I have a new stab, new CC Edge 130A ESC, new DNA 150A ESC and my motor back from Neutronics. The bearings were bad. Soon as I get my cast off, I can put the Jolt back together. A rookie's plane got away from him, and his plane hit me in the arm, chopping my arm and hand up and fracturing my wrist. Right now I actually wish I had a prosthetic arm and hand for my other amputee arm. Oh well; things happen.
Old Yesterday, 12:54 PM
ehelibuff
ehelibuff's Avatar
Joined Aug 2014
spinner
Originally Posted by hubcapsteve View Post
If you didn't do damage to blades you can do this....
Where did you get this spinner? Did you do this?
Discussion Micro Shrike Build Thread (was Mystery Build Thread) AndyKunz Electric Plane Talk 101 Dec 05, 2013 09:50 AM
Discussion Swist F5D build and fly 250mph+?! henke High Performance 391 Oct 18, 2013 11:21 PM
Build Log Build thread for my F5D fuselage used at the WC Troy High Performance 3 Sep 09, 2010 03:39 PM
New Product New Build thread for Viper F5D Model Rob AR High Performance 20 Sep 08, 2009 03:06 AM
Build Log Build Thread or not to Build Thread? - Redback malachite Slope 35 Feb 28, 2006 12:12 AM
