Thin, Medium & Thick or Crack filler. Some foam safe CA will take for ever to dry unless use with accelarator.
You can either put glue on one piece and the acc. on the other or put glue between both piece and once joined you spray the acc. Voila. I have assemble my new plane using only this stuff and it works great. Beats mixing and waiting for epoxy. |
Latest blog entry: Get Help by posting your SPM File
| Thread Tools | |
| Question CA Foam Safe white when dried. | macdaddy1199 | The Builders Workshop | 0 | Oct 15, 2009 09:49 PM |
| Question Must I Use Foam Safe CA With Elapor Foam? | Kenny Sharp | Hitec/Multiplex USA | 7 | Jan 14, 2009 11:12 AM |
| Discussion Can you foam safe CA for reglar CA applications?? | Flyextreme | Electric Plane Talk | 6 | Feb 08, 2008 08:31 AM |
| Discussion Question on using Foam SAfe Ca on EEP Foam. | DanT | 3D Flying | 2 | Nov 27, 2006 09:16 PM |
| Careful! FOAM SAFE CA GLUE ....not so safe ! | inventing_man | Foamies (Kits) | 15 | Jul 26, 2006 10:01 PM |
