Old Yesterday, 12:08 AM
United Kingdom, England, Stafford
Joined Oct 2013
Originally Posted by Mera'din View Post
Is there such a thing as "indoor" mode? For example, There will be occasions where I fly in a gym and I would hat for the copter to fly through the roof as it tries to RTH should something happen.
I wouldn't be in loiter mode, just 2d or 2d plus hold. What happens in a failsafe and there is no gps lock.
My fear is that in a gym I could get a gps lock and have a failsafe condition trigger a RTH. I would hate for the copter to take off into the rafters.
I suppose I could just set the failsafe to be land on these occasions.
Failsafe will only trigger with a loss of RX signal, or if you've got a switch assigned to RTH test. I regularly fly in my house for 10-15 minutes at a time with no problems at all. Sometimes it gets a GPS lock and sometimes it doesn't.
Of course, if your RX was to fail and it has a GPS lock, it would go into failsafe and try to escape through the nearest ceiling You could make a shield which fits over the GPS module to stop it getting a GPS lock or (as you've said) simply make it land on failsafe.
Vortecks is offline Find More Posts by Vortecks
Old Yesterday, 12:11 AM
Joined Oct 2013
Originally Posted by moshen View Post
On Vector Return To Home failsafe, if I have it set to a mode switch and I lose radio signal it goes into RTH mode. However what happens if it regains signal? Does it come out of RTH since it now sees the mode switch signal to what it was before failsafe happened? Just wondering since if it was in rate mode before RTH failsafe, then regains signal it will be in rate mode again and that can cause a quick crash..
Unless I'm mistaken, when it goes into failsafe, a message appears saying "move sticks to cancel RTH".
If it regains signal, nothing will happen unless you move your sticks.
Old Yesterday, 01:28 AM
Mera'din's Avatar
Joined Dec 2006
I am using a Frsky Rx that uses an S.Bus hookup. If I am understanding this correctly, I need to hook up the RX to a BEC or run a wire from the PSU harness to the RX right? No power is passed through the Vector from the PSU to the Servo/Rx pins correct?
Also, my Rx outputs a RSSI feed which, if it is the same as all the other FrSky Rx's is PWM. Where does this get hooked up on the Vector. I am using a FrSky TFR8SB.
Mera'din is online now Find More Posts by Mera'din
Old Yesterday, 06:12 AM
Australia, NSW, Castle Hill
Joined Mar 2013
Just curious if any of you have flown or still fly the MyFlyDream FC and how you would compare the Vector to that FC?
Thank you
Chris
v2rocketeer is online now Find More Posts by v2rocketeer
Old Yesterday, 05:10 PM
Joined Jun 2013
Today when i plugged in the battery (as usual) into the Vectors psu some spark and smoke came from the unit, I unplugged it and waited a while and plugged it in again, This time it behaved as usual but it thinks its flying or something because its counting the MAH used and i cant enter the menu, because its flying it says... This happened for anyone else?
Agalloch is offline Find More Posts by Agalloch
Old Yesterday, 05:36 PM
Kauai
Joined Jan 2011
Anyone have the" free fall detected " while climbing rapidly?I went up 200 feet in a few seconds on my quad and that's what it blinked!
Kauaiguy is offline Find More Posts by Kauaiguy
Old Yesterday, 06:46 PM
United States, CA, Woodside
Joined Mar 2013
Originally Posted by Arck View Post
Hi guys is there a how to for fixed wings? Mine is incontrolable with the Vector, I know the problem is a bad setup but is there a how to or todo list to make this?
Arck, as Thrashie said come on over to the fixed wing side, and post a picture of your fixed wing so we can see how your Vector is mounted.
We will get you sorted out.
http://www.rcgroups.com/forums/showthread.php?t=2196588
Willyspu is offline Find More Posts by Willyspu
Old Yesterday, 11:34 PM
Not my first rodeo!
_Savannah_'s Avatar
Joined Aug 2014
Having an issues I know others have struggled with. Running a Futaba 14SG and Futaba R7008SB receiver. I can't get through the Rx Wizard, does not see the Rx.
I see allot of post on the subject, I don't see posts with the resolution. I have updated the firmware. What am I missing.
Eagle Tree's website is down at the moment. Anyone else having problems there?
Appreciate the input.
Happy Holidays!
Cheers,
Savannah
_Savannah_ is offline Find More Posts by _Savannah_
Old Today, 01:13 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Have you tried not using S-BUS output, and just using the regular servo outputs from the Rx
to the Vector?
Have you plugged a servo into each channel in turn, and moving the appropriate control to make sure
that the Rx is actually outputting each control to the channel you think it is?
Daemon is online now Find More Posts by Daemon
Old Today, 03:19 AM
Not my first rodeo!
_Savannah_'s Avatar
Joined Aug 2014
to the Vector?
Figured it out. New to sbus, and did not realize that Futaba ships that Rx in Mode A. Switched to Mode B and the Vector sees my Rx/Tx and got through the wizard fine.
Not in the air yet however. Vector only sees my three position mode swith in the two farthest positions, does not recognize it in the center.
Also, I can arm the multirotor but after that MR will not show throttle input? I have tried several suggestions from other threads but the MR simply won't start the motor when I give throttle. I have a feeling it is something to do with throttle trim and fail-safe, but have not been able to resolve it.
Old Today, 07:01 AM
I'd FPV it.
Ho-Jazz's Avatar
United States, GA, Winder
Joined Nov 2009
Did you reverse the throttle channel in your futaba radio? I forgot to do that with my 9c and the vector did not like it.
Ho-Jazz is online now Find More Posts by Ho-Jazz
Old Today, 07:25 AM
Not my first rodeo!
_Savannah_'s Avatar
Joined Aug 2014
Throttle channel is reversed. I did that before I calibrated my ESC. I re-calibrated, just to make absolutely sure. I reversed the throttle channel when I calibrated my Maytech ESC's. I am out of ideas for tonight. I hit it hard on rc groups and google all night and can't come up with a solution. Ugh!
Old Today, 10:14 AM
The Sum of all Evils
Thrashie's Avatar
United States, FL, Largo
Joined Apr 2014
did you re-run the RX wizard after making changes to your radio?
Thrashie is online now Find More Posts by Thrashie
Old Today, 11:23 AM
Zero Cash Money
United States, CA, NORTHRIDGE
Joined Nov 2013
I take it you disconnected the USB from it before doing this? in your video display what does it say after you arm? if it is arming it is seeing the correct throttle since it uses throttle and yaw stick position. Check the end points of your 3 position switch... in the rc tab in Vector, as you move sticks and switches are all the sliders moving in the direction that you are doing on the Futaba?
D Dale is online now Find More Posts by D Dale
Old Today, 12:23 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Keep in mind you need to confirm the aircraft type in the OSD
on first usage after configuration. If you don't, it wont' run the motors (or anything else).
Discussion Dreaming about Multi Rotor setup : Multi+GoPro+eagle tree everything? crashtested Aerial Photography 10 Apr 05, 2014 07:46 PM
Discussion Why are we up in arms about quad over flights, but not about this? branflakes Multirotor Talk 1 Aug 09, 2013 04:26 PM
Discussion a good interview about gun control and why we carry ... logan5 Life, The Universe, and Politics 8 Jan 08, 2013 07:43 PM
Discussion I just had the wildest dream about FPV jhroof FPV Talk 0 Sep 04, 2012 10:55 PM
Discussion Pitch curve, we talk about anything and everything scale heli here cap231ex Scale Helicopters 1633 May 17, 2012 02:50 PM
